DSG Transmission
  • #31
    Originally posted by Ozsko View Post
    Ask the question the other way, why would there be a neutral ?
    So you can tow the car or winch it onto a tilt tray when it breaks down (I'm sure all our Tiguans will meet a tilt tray one day lol).
    Also if you need to push the car around.
    Although 99.5% of the population would never use neutral nor would they know what it does for the 0.05% it comes in handy.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    • #32
      Selective quoting changed the whole context of what was originally written. I know why there is a neutral but that was not the context of what I wrote.
      • #33
        Originally posted by BinChook View Post
        Would this be an issue if the rears were lifted and front wheels were rolling on the ground? Can we assume if front is lifted,the rear Hadlex clutch pack is depressurised and disengaged, it’s apples?
        No transmission still is turning and if the engine is not operating there is no lubrication happening. You need to put your car on a flat-bed truck or you'll risk doing serious damage to you transmission.
        - Tigger73's 125TSI Build
        • #34
          Ask the question the other way, why would there be a neutral if VW knew it would damage the box? In reality the car selects neutral when it comes to a halt when the first motion shaft between the motor and box stops spinning, all manual cars do this as it is the drive splines on the clutch plate that causes the gearbox to engage with the motor. When this happens and the first motion shaft stops nothing in the gearbox rotates or pumps anything unless the oil pump is electric.
          I know how it works, and I agree that engineers surely wouldn't deliberately design an inherent flaw such as this.... but I was unsure if there was a separate oil pump/active lubrication in the DSG boxes, as opposed to simply operating like a traditional box or diff, where the bottom of the gears bathe in oil & flick it all around while in-motion.
          I will try to find the various concerns I've read and post the links, to demonstrate my question.
          To clarify.... MY question is about when stationary at lights, ie: wheels/shafts are not rotating.
          My apologies to OP for hijacking the thread - it wasn't intended!
          2016 Skoda Octavia 162TSI RS Wagon
          (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
          Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
          • #35
            My understanding is that the gearbox is not being properly lubricated unless the engine is running. Which is why in the owners manual it says not to tow in Neutral as you can do damage to the gearbox by overheating/friction while not being properly lubricated.
            I don't think that there is any problem with doing what you are by moving to Neutral at the lights (with or without engine running). As long as you're stationary there's no issues. I doubt it provides any benefit otherwise it would be recommended in the manual.
            Also the problems with overheating tends to be with the older versions of the 7 speed DQ200 dry clutch DSG in the lower power/torque Golf/Polo/Passat. It has never really been an issue with the Tiguan as all models use a wet clutch (either DQ250 in FWD models or DQ500 in AWD). The wet clutch boxes have a lot less issues with overheating and so I maybe see some reasoning to do this in a DQ200 equipped car but not in a Tiguan.
            I use neutral sometimes when moving cars around in the drive so that I don't have to do a cold start. That's about the only time I use the Neutral gear.
            • #36
              I have this GST "clunk" in my MY2018 Tiguan Mk2 with 60K kms on the clock;
              Going to the mechanic tomorrow. Any ideas if it's the clutch, mechatronic or something else? It sounds like it happens when the gear changes from neutral to in-gear, but it's pretty much all the time when driving as well, it's just much easier to hear when reversing from stand still and then letting go of the accelerator. Also, my gear change from D1 to D2 is especially jerky.
              Edit: audio only: https://drive.google.com/file/d/1GB1...ew?usp=sharing
              132TSI Tiguan Allspace
              • #37
                I would guess clutch packs from my experience, but hard to tell. Are you taking it to VW?
                Change from 1st->2nd or 2nd->1st is notoriously 'clunky', so I daresay VW will say it is 'normal'.
                Goodluck and let us know how you go.
                2019 Tiguan R-Line - IS38 Turbo - Spectuned - X-Force Downpipe - RS7 Spark Plugs - CTS Inlet Elbow - ECS Inlet Pipe - K&N Panel Filter - Golf R Muffler - APR Exhaust Controller - Superpro Rear Swaybar - Digital Dash Retrofitted - 034 Dogbone Mount - DBA T3 Rotors & Pads - Golf R Springs
                • #38
                  This is definitely not clutch pack! Search my posts .I get this problem since the day 1. I purchased car . And after3.5 years fighting with VW Crooks and only on end when DSG Started to jump on resume and to roll back on hills and was dangers to drive , than they replaced with complete brad new transmission with latest revision ( new clutch pack default installed ) + in set with new bevel box mounted ( as was also leaking since day 1) at VW Factory shipped from Germany jus to bolt on here on my car . And it didn't resolve issue what you demo here in your video! VW just unable to Tiguan clunking doggy drivetrain !
                  Lots of same issue world wide with exact DQ500 DSG on MQB Skoda, Seat VW. I think even Audi q3 new one has on forums same reports with clunking .
                  Let me know if you find solution or Fix for this clucking going back and forth, reverse, slow drive etc...
                  Best to check Sight quick tap on gas pedal and going slowly in circle with full wheel turn to Left or right on big parking empty space, and you will notice even more how Bad is this rubbish DSG Drivetrain made ! Should be not sold and made with this embracing factory production fault!
                  • #39
                    Yes VW dealer. There's also quite a bit of jerk in the car when this happen. It's not isolated to only when reversing on a slight incline, it's just the easiest way to demonstrate.
                    • #40
                      So I've been told this is "normal operation of propshaft back lash".
                      Any comments?
                      • #41
                        Any comments?
                        Yep pretty standard response. You can try taking it to a different dealership and see what they say? At least you have it on record that it’s been checked should it get worse.
                        You can then either live with it or start replacing bits yourself.
                        • #42
                          Any idea what it cost to fix?
