Tiguan 2020 Mid-Life Update
You would anticipate the GTE concept might be something resembling an R-Line front bar. They definitely need to clean up that overly 'heavy' design and that looks like a solid improvement.
Although your "standard" spy shot has Mk7 Golf R/R-Line overtones to it's shape/design.
i think the bottom 2 are the touareg mk3 under test. With camouflage/covers over the new front grillOriginally posted by tigger73 View PostI know this is getting in early but there's a few pictures floating around of the mid-life update that will be coming out for the Tiguan (likely) in 2020.
GTE concept with new front end:
[ATTACH=CONFIG]40439[/ATTACH]
[ATTACH=CONFIG]40440[/ATTACH]
And some spy shot of a new front end for the standard Tiguan:
[ATTACH=CONFIG]40441[/ATTACH]
[ATTACH=CONFIG]40442[/ATTACH]MY18 Golf Alltrack 135tdi - DA pack, SL pack without sunroof, Info pack : tungsten silver
I think you could be right here. On closer inspection there is a cover over the lower section of the upper grille (between the number plate and the badge). The wheels/car also does look heavier too.Originally posted by limiteded View Posti think the bottom 2 are the touareg mk3 under test. With camouflage/covers over the new front grillLast edited by tigger73; 06-12-2018, 01:08 PM.
I like the GTE design front bar. I'd have it on my car. I agree that the current R-line is a bit heavy on the styling and doesn't necessarily balance/blend well with the rest of the car.Originally posted by Dutch77 View PostYou would anticipate the GTE concept might be something resembling an R-Line front bar. They definitely need to clean up that overly 'heavy' design and that looks like a solid improvement.
That blue GTE would be spot on - right front bar, right colour and right wheels eh.
Far sportier/better looking than existing R-Line set-up. I absolutely suspect they will fix that issue on the FL.
