Originally posted by Zachild
View Post
No Reverse Camera or Area View - "stuck" in Park Pilot only
If problem is not displaying only rear camera but rest 3x camera working fine than problem is rear camera or cable ,connectors. But if not any camera is working than all smell on faulty AW2 module which has felling BGA chips by vibration ,heat etc.. . Take the terminal Plus from Battery wait for 10 min put it back , check it out if is working now fine .If after this happen randomly again this could be AW2 module need replacement .Before any replacement I would always check all cables and connectors are inserted properly on each side of problem affected hardware in chain and make sure there is no bent or damaged cables or pins.
Is always best if you can fix yourself problem ,as going to dealers in many case they even make more issues by digging.
VW Dealers electrician are 90% butchers with basic knowladge '' take and replace what ever cost '' .
They usually follow Elsawin and technical manual instructions . Skilled stuff with ability self problem slowing and diagnosing using brain and logic is unknown territory .. As result high cost to Dealer which are passed in most case to Owners and in most cases broken other things and lots of time waisted.Last edited by cameleon72; 14-06-2019, 12:18 PM.
I fixed my reverse camera by replacing the following harness -
Harness 3C8-971-192-C | VW Parts Vortex
I did it myself so it's not that hard. Been about a year now and no recurrence of the issue.
It worked immediately afterwards. The old cabling had wires cut from rubbing.2009 CC 3.6
