G-8VXWWTRHPN Tiguan Towing - VWWatercooled Australia
Tiguan Towing
  • Tiguan Towing
    Hi all - i thought id start a new thread regarding towing capacities.
    First of all I have on most reviews that towing up to its max capacity of 2500kg is merely impossible due to the towball max download of 100kg however I have found another company that has a towball download of 140kg.
    Has anyone used these or heard of these before? If not what towbar is every using?
    TIGUAN | Towbars Australia
    Hayman Reese = 100kg download weight
    Hayman Reese designs, manufactures, tests and distributes vehicle towing systems including towbars, weight distributing hitches, sway controllers, cargo barriers and a wide range of accessories.
    Current Rides
    2018 VW Tiguan 140TDI | Indium Grey | R-Line | DAP |
    2010 Yamaha XJ6 | 2016 Honda Grom |
    The towing limit of any vehicle is either the limit imposed by the manufacturer of the vehicle OR the capacity of the towbar
    WHICHEVER IS THE LESSER
    The towball limit is set by the MANUFACTURER of the vehicle and should not be exceeded for engineering reasons.
    Doesnt matter what the towbar maker says. Even if you put the higher capacity one on you hsould still not exceed the 100kg set by VW.
    Or you may end up like Xtrail owners that the towbar bolts pulled out of the chassis
      ^ what he said.
      A tow bar manufacturer cannot exceed the limitations stated by the vehicle manufacturer (regardless of what they advertise).
      There is nothing stopping you towing a couple of tonne with under 100kg tow ball mass. What matters most is weight distribution within the trailer, axle position and travel speed. It is common in Europe to have towball mass in the 5 - 8% range (of gross trailer mass).
        Originally posted by doc_777 View Post
        ^ what he said.
        As an ex caravanner it is worthwhile pointing out that Euro vans are built rather differently to Aussie behemoths and tow rather differently to ours. Hence they have lower ballweights. An Aussie built van can be unsafe to tow with a 5% ballweight due to its weight distribution nad usually is recommended to have AT LEAST 10% ball weight of AGGREGATE trailer mass EG van weighs 3000kg loaded 300 kg ball
          Ex-caravanner here too - which is why I specifically raised the point about weight distribution. And you will notice that a lot of Jayco vans (the largest manufacturer in Aus) now have a lot of vans with much lower than 10% of GTM towball mass.
            Never liked Jayco they are like certain body parts Everybody has one. But I take your point and it is also affected by how much and where its put. When Gran and Granny take the whole house and just load her up and away we go. Groan goan goes the engine LOL
              Good point! I believe that the various roads authorities are infringing an ever-increasing number of grey nomads for exceeding GVM (and GCM in some cases) for loading up their dual cabs and hitting the road.
              What I think the Euro’s got right was (effectively) a monocoque construction, and centralised mass for heavy things like kitchens. The front or rear kitchen in Aussie vans is a uniquely Australian thing it seems.
                Are there any Euro vans imported and sold in Australia?
                2018 Allspace 162TSI R Line
                  Yes but be very careful buying one and make sure it is fully compliant as English gas regs are different to here and all piping etc must be replaced as well as some appliances Some electrical stuff is also not compliant.
                  Brands are Adria, York,etc. Jurgens which are imported and fitted out here and would be the safest buy.
                  Private sales could be dodgy because people can import non compliant vans and use them but they must be fully complied if they sell them and SOME ARENT
                    Good news (if a bit premature)! Apparently there is an internal memo from VW going around stating that the Mk2 Tiguan's tow bars will be rated for a downball weight of 200kg. This applies to new vehicles and will also apply retrospectively to ones already sold!
                    Apparently prospective buyers are being informed of this. Just thought you guys might like to know and also to keep an eye out for a formal memo to post up in the forums.
                    Current:
                    2017 Mk2 Tiguan 162TSI, R-line, White
                    2020 Mk7.5 Golf R Wagon, White
                      Just to be clear on the regs on this It states the towing limit to be what the manufacturer rates the vehicle at or what the towbar is rated at WHICHEVER IS THE LESSER and the towball weight is the VEHICLE manufacturers set limit
                      As I understand it VW are uprating the towball capacity of the VEHICLE which means that it will only apply to new vehicles.
                      Maybe they will make it retrospective but I doubt it. Toyota didnt in the 90's when they upped the 80 series rating from 2500kg to 3500kg but refused to certify older vehicles which were identical. Hayman Recce however recertified their towbars to suit.
                        It would be great to get clarification of this uprating and how it will apply
                          I contacted VW Australia and got this repsonse.
                          "Thank you for contacting Volkswagen Australia.
                          In regards to your enquiry, it is correct that the MY19 Tiguan has an upgradedtow ball down weight of 200kg. This is also retrospective to Generation 2Tiguan's like yours. In order to meet the new compliance you will need to visita Dealership for the new labels and owner's supplement."
                          Tiguan 162TSI R-Line | Tungsten Silver | DAP | MY18
                            Tiguan Towing
                            I've been told the retrospective increase in towball reading is only applicable to 162TSI models
                            Current:
                              I have enquired about tow ball ratings being upgraded, would be nice to have the 200kg on my 08/17 Tig Adventure, but servicing dealer folk in Melbourne do not know about it. I called my previous long-time VW dealers service folk further North, who said that they did have the 200kg rating sticker set.
                              However they rang back, as they found a VW Australia notice sent just after Christmas ('easily missed' by some he expects) that rescinded earlier advice concerning the 200kg upgrade previously issued! Current Allspace & Tigs remain as specified in the respective Specification Downloads = 100kg. 'Genuine' Best Bars' fitted to mine before delivery.
                              2017 Tiguan Adventure, 2018 Golf VII Comfortline
