There's a bit of annoying cost cutting in the new ROC, like no aircon in the glovebox and no cig socket in the boot.
So I want to run a 15l fridge in the boot on forthcoming road trips. The fridge only requires 40W, or less than 4 amps.
Does anyone know of any unused wires in the loom (maybe a trailer harness? ) that can be easily tapped into?
Otherwise I will have to run a cable from the fuse box to the rear and put a merit socket under the floor in the spare wheel well.
I can't find an obvious spot to go through the firewall from the engine fuse box which would be preferable and easy to put an inline fuse that's easy to get to. Under bonnet connection would also more easily make 15A available in the boot if ever needed.
