I'm also curious about the comments being made regarding load capacity / tow capacity in relation to engine cc.
Am I correct in saying 5th and 6th gear are 'over-drive' gears? If so, and I'm happy to be corrected, then when towing a 2t + load (in fact any load ???) or have a full tray of camping gear (or fencing gear etc) the 1:1 ratio (4th?? in the 'Rok') should be used if you want to avoid expensive gearbox re-builds. I've always been told by mechanic mates not to tow anything using overdrive. What I didn't do was heed the warnings as far as load carrying was concerned - market leading dual cab tray full of gear for extended trips, weekend trips, soil rocks etc + many k's travelled using 5th = paying mechanic many $ to re-build gearbox after destroying 5th.
If what I have said is correct then Gavs comments about 'dropping back to 4th' are words that should be noted. The 6 ratios are there to use as dictated by load and road conditions not just a means to get into 'top gear' on the open road and 'cruise' @ 100, 110 or 130km/h.
After my 'short' test drive on Saturday I can safely say the Rok drives a shed load better (and with a lot less fuss) in 4th @ highway speeds then any of the competitor dual cabs I've test driven (note all, including the VW, have been unladen).
nt
nt
