I want to connect up a 12v water pump for a farm spray unit. A temporary connection would be ideal as I will only be using it occasionally.
Can someone tell me how many amps I can draw though the 12v outlet in the tub? The pump spec says it draws a max of 18amp . I am guessing this is more than the inbuilt outlets can handle?
Alternatively the unit came with a 5m long harness that will reach all the way from pump in tub to battery and is fitted with two large alligator clips (like on jumper leads). Apart from not being fused, is there going to be any problem simply connecting the + to post on the battery and the - to the chassis? An obvious issue is fitting the alligator clip to the + post with the bonnet closed. Have to remove the protective cover to allow it to fit and maybe make a temp insulator to prevent clip inadvertently touching bonnet.. tia.
