Auto lane change
If you don't already have the added option under Assistance Settings > Travel Assist then no. I doubt Volkswagen Australia would be offering this option.
However, because you've got a 2023 model you may be able to enable it via coding.
You car will need the following:
1. Lane Keeping Assist
2. Travel Assist
3. ACC
4. Park steering assistant - Control unit 76 5WD919298 5WA919298 or 5R3919298 (12 sensors)
5. Control unit A5 (front camera) at least 5WA980653D software version 3400
If your car meets the pre-requisites above then the instructions for enabling it with OBDeleven (at your own risk) are:
1. Control unit 09 - Adaptations
- BCM driver assistance turn signal functions:
- Travel_Assist_Blinken: Active
2. Control Unit 44 – Long Coding
- Qfk_ma_function: Active
3. Control unit A5 – Long Coding
- HC_Variante: Variante_3
- HC_mob_line: Coded
This option doesn't appear to be restricted by SWAP or FEC. But you do have to have the latest hardware introduced from around mid-2022.
