JB1 install problem
  • JB1 install problem
    Hi guys,
    Just installed the JB1 in my MY16 R. Physical install no probs, disconnected battery and fiddled around until all done. Plug 4 sucked as I had to access from underneath the car.
    All in, I connected battery and started car...only to get every error possible! Esc, auto hold, all sorts of things came up.
    Anyone with any experience installing the Jb1 or any idea why all of the error codes?
    Many thanks for any help anyone could give!
    MY16 Golf R
    If I remember correctly, take it for a drive and it'll fix itself.
      Originally posted by Russ View Post
      Hi guys,
      MY16 Golf R
      you always get heaps of errors when you disconnect the battery for sometime.
      "Forced induction" sounds like some sort of sexual assault.
      i drive a Golf 7R tuned by APR + exoticars
        It's because you disconnected battery.
        Go for a drive, find a car park, do some left & right U-turns & they should disapear.
        There will be low voltage codes - VCDS or similar can clear them.
          Thanks for the tips. Didn't realise that could happen. Once I saw the errors I turned the car off. I'll give it a drive shortly and get it sorted hopefully. Cheers.
          MY16 Golf R
            Keep us updated on how you go as I'm going to install JB1 soon as well. Thanks.
              Thanks again for the tips everyone. Follow what you said and all errors cleared within about 500m of driving. Jb1 feels pretty strong, need to do some full throttle runs apparently to calibrate it. Much bigger surge of power was obvious right away though. Will leave it on standard map 1 for now then tweak it after I get an intake. Cheers.
              MY16 Golf R
                you are supposed to wait at least 5 minutes after engine shut down before disconnecting plugs or they will throw a code. VCDS should be able to clear them. From DTUK install instructions.
                Tig 162 R-Line; Audi TT
                  Hi, what is the brand and how much for the JB ? i'm looking to get 1 too. where did you get it from ?
                    There is no need to disconnect the battery when fitting a JB1 just open the car and hood locate the car key away from the car and let it sleep 15 minutes before disconnecting the 4 plugs and attaching the unit
                    JB1 US$379 Management Cable US$35 so about A$650 with shipping
                    JB1 forum
                    VWVortex.com - Burger Motorsport JB1 Plug and Play Information Thread 7R and S3 Specific
                    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
                      JB1 forum
                      Check out these results JB1 + stock R wagon flywheel HP 364 Ft.lbs 365 or 272 Kw 495 Nm
                        I installed a JB4 on my stock bmw 335i - just on map 1 it made a huge difference in power. The hijacked dash gauges were really cool as well (stock fuel gauge would display boost pressure after certain throttle %)
                        If i buy an R, it would be great if BT bought out a Juice box like this for the R.
                        2016 -R- Limestone Grey
                          When i watched the guys at Hills Eurohaus i dont recall them disconnecting the battery to do the Jb1 install.
                          Gemini (Killed), Daihatsu Charade Sold, Peugeot 306 Convertible Sold , Peugeot 306 GTI 6 Sold
                          Ford FIesta Sold, Evo 7 Sold , Evo 8MR Sold , Megane 250 RS Sold
                          MK7R Lapiz Blue Sold
                          MK7R White Current
