Park Assist / Park Pilot - Questions and Issues
    Originally posted by DV52 View Post
    Kiaorana: interesting handle -I assume you are from the Cook Islands and you are saying "Hello", or perhaps you are using the Maori word for the same term. In any event, Hi in return!
    Regarding your Park Pilot problem - the reason for the message could be that you have not set-up Park Pilot in the car's MENU correctly.
    Unless you tick the box that says something like "activate automatically", Park Pilot can only be engaged by pressing the "P" button on the centre console.
    Just a hunch, but it might be prudent to check the following:
    1. Press the CAR button on the escutcheon plate on the RHS of the infotainment system
    2. Press Set-up on the lower RHS of the screen (looks like two gear wheels)
    3. Select parking and manoeuvring
    4. Make sure the box next to activate automatically is ticked under Park Pilot section
    5. Exit all menus
    Don
    Hi Don,
    Sorry I didn't see your reply earlier! You're right KiaOrana comes from the Cook Islands where I grew up!
    Park Pilot is configured properly, it's definitely a car issue. It always tries to park in the bay with a car, instead of the free bay.
    Have a good one!
    Sent from my SM-G925I using Tapatalk
      Originally posted by Kiaorana View Post
      Hi Don,
      Have a good one!
      Hi Kiaorano,
      I had a play with the auto park system today and it also tried to reverse me into spots where cars were already parked.
      Not ideal!
      Sent from my GT-I9505 using Tapatalk
        Interestingly, I took my car to VW where they cleared a fault, and since then, the park assist works perfectly.
          I had another go last night and it worked fine on that occasion. If it does it again ill notify the dealer next time I'm there.
            Did they get a technician to go out and demonstrate with you/ you show them?
              They actually called me at work to tell me they couldn't see what was wrong. So I went there, took a technician with me, headed to the closest woolies to demonstrate how 80% of the times, the car would go for the wrong spot .... And of course, it now worked every time!
              The technician told me they cleared a fault related to park assist and that it was very likely the reason why it worked now.
              It's worked ever since.
                Hi All,
                Silly question: how do I select the parking mode: parallel or perpendicular in park assist?
                Thanks.
                  Press once, you get parallel, press twice you get perpendicular. I believe perpendicular is only available on cars with DAP2
                    I will try mine again tonight but yesterday I pressed it twice and it just turned it on and off for parallel parking. I have the driver assistance pack so I am meant to have both perpendicular and parallel.
                      Hey Kiaorana, perpendicular is available for both DAP and DAP2
                      Both our cars have it.
                      Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
                      Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
                        See that's why I love our community! You never stop learning! Thanks agentthumb! [emoji106]
                        • #27
                          No worries
                          The parallel park function is brilliant, I use it all the time (I consider myself a pretty good parker, but the system often does it quicker than I can and with much greater accuracy). I would say it does the job 9.5/10 times.
                          Perpendicular parking however, the system does some pretty silly things. Where I can get the car into the spot in one go, the car would often go back and forth a few times before fully parking the car. It's almost like it has to line the car perfectly straight spot before it'll back into the spot. So I never use it for perpendicular parking. Tho I can see it being a great system for someone who is not very confident with parking themselves
                          • #28
                            My auto parking in reverse parallel was fine.
                            Reverse bay parking on both sides was faulty.
                            Would miss spots and at times tried to park in occupied spots.
                            Under warranty VW replaced the parking aid sensor.
                            All seems fine again.
                            • #29
                              "Park pilot is not available"
                              Hi all, I know this topic might of been mentioned before but I couldn't see anywhere which had a solution.
                              Basically happened twice within a week now. The message "Park pilot is not available". I can hear the camera cap move but no back up camera displays on screens. Each time I have to switch the car off or hold the mib power button for 10 seconds or so to restart it. This is on a 3 months old MK7 R.
                              My question is, has there been any concrete solutions around this? Or do I just have to accept this is one of the joys of having a crappy mib 2 system? Never really experienced this annoyance with other cars with a back up camera. Thanks all!
                              • #30
                                It's a known bug that is yet to be fixed.
                                I had my software upgraded to version 624 (I told the dealer I wanted it done) but it hasn't fixed this or the on-going CarPlay issues.
                                AFAIK, there's no ETA on a fix either.
                                MY08 Mk5 GT Sport - sold
