So I have a 90tsi confortline. I noticed rattling noise from about 2k mileage that occurs on and off at the front on the driver side.
The noise cannot be reproduced as it is intermittent, of uncertain origin and there does not seem to be any particular trigger to it.
I reported and got the car checked by dealership twice but they could not identify or reproduce the sound. First time they put Wastegate clip as "this" was a known issue. Second time they "tightened the bolts".
Noise persisted.
I Moved interstate meanwhile and got a different authorised vw servicing to look into it. Same problem in that they could not identify or reproduce.
I then complained to vw Australia and was referred to alternative authorised vw servicing for extensive testing. I Went for a ride over hour and the noise finally manifested. The technician to note, although it wasn't as loud as usual on that occasion and lasted just a few seconds, but good enough.
The Authorised servicing vw performed their investigations etc but could not identify the cause or fix the problem as it wasn't a usual issue. They referred problem to vw Australia and were advised to try some steps.
They effectively took apart and insulated the fuel pipeline and after extensive testing concluded that definitely fixed all problem. (about 300km of testing altogether on a 6000km car)
I got car back, drove 2 km out and noise occured again, but this time softer. I think the solution they got worth the insulation is on the right track but still needs work.
I dropped car off again and waiting for their further investigation.
Any similar issues or ideas anyone?
Sent from my C6603 using Tapatalk
Noise persisted.
