So I've now had my 90TSI comfortline with driver assist for a couple of days. Driving it home the first day, I noticed this quiet noise coming from the front right...sounds a bit like a small pump or something of that nature. I then didn't hear it for a few days, but tonight I drove the car a little more vigorously (I've been babying it in the meantime) and heard it again. Seems to kick in somewhere between about 2.5 and 3.5k RPM but not all the time. Any ideas what it might be and if it's normal? It's not exactly an unpleasant noise (not loud or grinding or anything like that) but it's not something I was really expecting to hear either...
Quiet electro-mechanical noise from front right around 3000rpm
Originally posted by caeci11ius View PostAny reason you'd expect to hear that only when driving moderately (as opposed to very gently and trying to get awesome fuel economy?)? I'd have thought pumps for coolant would be running constantly...
The new fully-electronic coolant control system of the TSI enables significantly more efficient thermal management with a shorter warm-up phase; this reduces friction losses, which efficiently improves fuel economy. A new type of rotary vane module was developed for intelligent thermal management control. This makes it possible to fully block coolant entry into the engine or adjust to a minimal volumetric flow in the engine warm-up phase. In the hot operating state, the coolant temperature can be adjusted quickly and fully variably to various temperatures as a function of engine load and external constraints.
Video where you can hear the noise. You hear it starting at 1/4 through to about half through, then some more in the last quarter...
Link: https://drive.google.com/file/d/0B6k...it?usp=sharing
Probably cooling fan — took my new TDI110 Highline on the freeway for the first time this afternoon.
Four adults on board, didn't go far (Chandler Highway to Burke Rd and back) with a 2K suburban street run at the end — which ought to have sufficiently cooled the turbo.
When switched off in the garage a fan at front right ran for about 6 minutes — sounded like a buzz-saw and obviously isn't properly balanced, as it vibrated the bonnet and front guards to the extent that I actually checked that the engine was turned off (it was.) It sounded louder than an idling diesel and had at least as much vibration!
Originally posted by wai View PostCould be the headlight level adjusting motor.
On my old Mk 6 the headlight motor could be heard,but only just — besides, it has to be run from the dash (halogen lights — not xenons and anyway they were turned off.)
I now think it is the waste gate after all...drove it with the window down last night and it sounds more like that than it did with the window shut. Seems to flutter more rapidly than the other ones I've seen posted so it sounds a little different but definitely more like it once you open the window. I assume that's a a quick and simple repair then (if it's that?)?
Originally posted by wai View PostNot if there's a fault causing it to be run.
The noise can only have been one or both cooling fans running flat out (I believe there's a pump to cool the turbo on the Mk7 TDI, but any noise from it should be muffled — this was frighteningly LOUD, very obvious and vibrating the front of the car, which those tiny motors just couldn't do.)
When it shut off after about six minutes it ran down rather than just stopping, which again suggests fan or fans (there are two.)
Next time (if there is one — probably will) I'll look further into it — just thought it might help the OP to locate the source of his/her noise.
