FYI, 'BlueMotion' is an umbrella term used by Volkswagen to promote their fuel-saving technologies. These include, but not limited to:
- Start/stop system
- Regenerative braking
- Lower idle speeds
- Taller gear ratios
- Gear shift indicator
- Engine technology (turbocharging, direct-injection, cylinder deactivation, optimised engine management software)
- Aerodynamic design
- Lowered suspension
- Low resistance tyres
- Weight reduction
Not everything on that list applies to all models, irrespective of whether or not the BlueMotion moniker is plastered all over the car.
In regards to the Start/stop system itself, you should read the owners manual carefully if you haven't already done so - this tends to answer 90% of queries asked by owners on this forum.
If you are still having difficulties, then you should explain to the salesperson what the issue is (even if you can't demonstrate the problem), who may clarify your understanding of how the system works.
If the problem persists, then there may be a technical fault - in which case, you'd need to book it into the dealer's workshop.
- Start/stop system
- Lower idle speeds
- Weight reduction
