Originally posted by Brendan_A
View Post
Launch control.
Launch Control
Dont know about golfs but in my TTS put it in sport mode, magnetic ride on, ESP off, left foot on brake, right foot flat to the floor, it automatically goes to correct launch RPM which can vary depending on tune, let off brake and hold on for dear life.. Best done on a safe road with a high speed limit.
Sent from my iPhone using Tapatalk2010 MY11 Volcano Red Audi TTS 12.2@111mph
APR Stage 2+, BPS DSG Tune, Turbo XS downpipe, Autotech HPFP, GFB DV+
DBA T3 Front Rotors, Brembo Rear Rotors, Remsa Brake Pads, Nitto Invo Tyres
Launch Control
It may not be a feature on the DQ200. I'm guessing it has been disabled to extend the life of the gearboxes.Originally posted by kure69 View PostI have been trying this on my golf 7 90 TSI and have had no luck. Can some confirm that this activated on the 90 TSI please.
you can only turn esp partially of in the gti and for the first time completely off in the golf r
i dont believe you can do it in the others.2014 Limestone Grey Mk7 Golf R
DSG, Leather, Drive assist.
APR Carbonio Intake // APR Boost tap // APR Stage 1
One question. Why?
The OP has a 110TDI, so my question is why would you want to launch it?Originally posted by BFPO40 View PostThe thrill, exhilaration, fun. Keep it on the track tough.
I'm guessing that because the OP has a diesel with the DQ250 DSG (same DSG as GTI and Golf R) that it may be possible. However almost certain that they wouldn't enable the feature in the DQ200 7 speed.
All of the previous Golf TDIs never had launch control, despite having the same gearbox as the GTI. I must admit, the Golf Mk7 TDI doesn't "launch" as well as my old Mk5 TDI, but then I haven't tried to disable the ESP/TC/whatever to see if will return to it's former glory.
Launch control.
So does the 110TDI have LC?
You could still see if a car is capable of being launched without physically launching it. Go through the steps until you have the car bouncing off the rev limiter at 3,000rpm and then let the revs drop.
Launching typically knocks close to a second off the 0-100 time compared to just putting your foot to the floor.
Though does put extra strain on the drivetrain. On FWD models you may have issues with traction - which is probably better for the drivetrain but worse for tyres.
Like anything, if you do it to excess it can cause damage, but in moderation, no. There are GTIs and Rs with the same gearbox (and quite possibly the same spec of clutches) packing a whole lot more than 320Nm, that cop launch control regularly. The figure bandied about as a sane limit for the DQ250 (and clutches) is around 550Nm.Originally posted by Eaglehawk View Post3000rpm on a 320Nm turbo diesel? Wouldn't that screw up the clutch?2008 MkV Volkswagen Golf R32 DSG
