Water leak and headliner mark
  • Water leak and headliner mark
    Just a little warning for those who have their Radio Software Update.
    Apart of the procedure of checking my car out for the problem of bad radio reception was to check the connection of the wiring on the antennas located on the rear window (Hatch).That checked out OK but the software update fixed my problem with regards to the radio reception.
    But today while cleaning my car I noticed a big wet water stain on my roof lining just under where the rubber grommets for the wiring loom for the hatch goes. Looks like water is seeping beneath these and coming into the car DOH, so hard to gets things fixed properly these days at Service Centre's.
    Just make sure that these grommets #2 photo are sealed after the work is carried out
    [IMG][/IMG]
    [IMG][/IMG]
    Oh yuk! Are they replacing your lining? Useless kids working in those places these days, with no care about others property.
    Sent from my GT-N7105 using Tapatalk 4
      What fools.... There is no need to check the aerials at all, confirm fault, carry out update and retest. Only if the problem persists would you start looking for further issues.
      Volks Handy
        The whole roof back there now is horrible, it isn't just a stain on the edge, nearly the whole back section is stuffed now, given the whole lining is presumably one piece....that means a total replacement, and some other twat who doesn't care will likely leave this with noticeable blemishes when replaced (e.g not properly put under the sill frame edging etc)
          I'm not sure what to do, if I ask for a new roof liner I would be very worried about some useless apprentice doing the job and end up with broken side mouldings, ill fitted roof lining and rattles. I might ask for them to get it cleaned by someone like a carpet cleaner and see if they can get rid of the mark. Then if that fails a new roof lining.
          I made a negative entry on this VW Dealers Facebook page, it's funny they got right back to me. Tomorrow I will be in to see them and the way I'm fuming I will be ready to give them a good ear full of what I think of their service centre.
          All the problem was with the radio reception was a software update and it was me that found out that information for them as they didn't have a clue, until I quoted something out of a overseas Forum.
            Originally posted by tonymy01 View Post
            The whole roof back there now is horrible, it isn't just a stain on the edge, nearly the whole back section is stuffed now, given the whole lining is presumably one piece....that means a total replacement, and some other twat who doesn't care will likely leave this with noticeable blemishes when replaced (e.g not properly put under the still frame edging etc)
            Exactly my worry also.
              Although this may not be 100% relevant seeing as it applies to a Polo and not a Golf, I thought I would provide my two cents worth.
              I had to have the entire roof-lining of my 2012 Polo replaced after I pointed out an area where it was not installed correctly and actually hanging down a bit. I had the same concerns, I was worried that the service tech's would do a 'shoddy' job, not install it properly and leave marks on the lining; however, I was pleasantly surprised when I found that after they had replaced it, you literally could not tell at all. It was a seamless job and done absolutely perfectly.
              Replacing a roof-liner is a pretty standard job and I wouldn't worry about them doing a bad job.
              If I were you, I'd go ahead and ask them to replace the roof lining. I'm sure you'll be impressed with the overall finish.
              Hope my experience can shed a little light on the situation!
              - Barracuda
              MY16 Golf GTI Performance Pack
              Previously: MY12 Polo 77TSI
              In The Family: MY15 Golf 103TSI Highline & MY15 Audi RS3
                - Barracuda
                Thanks for the reply it has given me some hope maybe with a total roof lining replacement I might get a decent job done, I know I will be telling them of my concerns about it being fitted properly in the strongest terms.
                  Absolutely! That's what I said to them. I stressed that I wanted it to be seamless around all the A, B & C pillars and where it meets the windscreen.
                  According to the service manager at the dealership I go to, it's a "fairly standard procedure and the technicians do it all the time".
                  Anyway, best of luck with the whole scenario!
                    My roof lining is water marked, going to get it checked out next week. Honestly the car has never seen rain (Brisbane Winter 2013) and I have not had the car back to the dealer to check radio reception etc. Bazaar
                    Passat Alltrack sports pack - silver
                    Mk7 Golf TDi White - 18" VW "Rotary" Wheels
                      Get them to replace the roof lining, if they do a crap job, get them to do it again, and again and again untill they do it properly.
                        Gee after reading your post I'm starting to think that this water mark thing is more common than I originally thought, also a guy on a South African forum has the same problem, I just can't think of where the water is getting in, other than the rubber boots where the wiring goes, on the hatch.
                        It's been 3 weeks since I took my Golf in to be checked and I was told the roof lining has arrived and it will be replaced next week.
                        I'm starting to get a bad feeling about my Golf as I have experienced another fault, driving around town the other day I stopped on a hill and applied the foot brake, I was suspecting the HSA and Park Brake to engage. The next minute the car started rolling back and I noticed a warning light and a message come on the instrument display "park brake malfunction". I tried numerous times to get the HSA to work but no luck until I pulled over and the stopped and restarted the engine, it makes you wonder how problematic this Auto Brake and HSA will be in the future when the car gets older.
                        Also the radio reception on FM with my car is really poor, as soon as you get around 10- 20 klm out of town the damn thing keeps fading out, I think this only applies to cars without the reversing camera option.
                          How are you going with your Roof Lining replacement. I had mine replaced finally yesterday and I must say I can't tell any problems with the fitment they have dome a great job.
                            Water leak rear headliner Golf 7 Wagon
                            Hi all,
                            I have just noticed a light water line, running from one side of the rear headliner to the other, has anyone had a similar issue? I've checked the rubber seals and can't see anything loose, anyone got any ideas as to the source of the leak?
                            My16 Golf Alltrack, DAP
                            MY18 Golf Comfortline
                              Got a sunroof ?
                              MK4 GTI - Sold
                              MK5 Jetta Turbo - Sold
