Has anyone else had issues with shock absorbers/bushes that won't shut up? Mine are driving me mad at the moment and car has been booked in to have it rectified hopefully. Worse on cold mornings.
Noisy Squeaky Suspension
Yes mine is driving me crazy too. Please let us know how it was fixed as my dealer claims there is no creak, as all ways they don’t want to investigate. I’m looking at buying new strut tops and bearings but I read somewhere that it took new shocks to fix the problem in the end. I have no warranty left so I’m looking for the exact fix rather than guessing.
Sent from my iPhone using Tapatalk2015 Golf R. Lapiz Blue.
My car has 10 months left of warranty, its so bad even my wife comments every time she's in the car. I'll let you know what they find.
Originally posted by Reedy View PostYes mine is driving me crazy too. Please let us know how it was fixed as my dealer claims there is no creak, as all ways they don’t want to investigate. I’m looking at buying new strut tops and bearings but I read somewhere that it took new shocks to fix the problem in the end. I have no warranty left so I’m looking for the exact fix rather than guessing.
It could merely be suspension bushes - I've not noticed it on either Golf, but my 1988 Cressida had in the front end for its entire 21 year life when going over sharp speed humps (of which I've always thought the inventor should be hung upside down...)
When a flexible bush reaches sufficient tension, it can move inside its mount - hence the squeak.
It may annoy some drivers, but it's better than the bush overstretching and breaking up.
I have had a new car every 3 years for the last 30 years and never had this issue the car only has 40000km on the clock so if the bushes are the issue they can replace them.
Originally posted by Idle View PostIt could merely be suspension bushes - I've not noticed it on either Golf, but my 1988 Cressida had in the front end for its entire 21 year life when going over sharp speed humps (of which I've always thought the inventor should be hung upside down...)
If that proves to be the cause, most likely all they'll do will be whack some rubber grease on them.Originally posted by Why? View PostI have had a new car every 3 years for the last 30 years and never had this issue the car only has 40000km on the clock so if the bushes are the issue they can replace them.
Had this on a 2015 Golf Comfortline. Audible to me virtually from new a noise when front suspension "extending" into dips on road or on descending down ramps and over speed humps. It got gradually louder and more frequent, audible to any passengers in the car, except VW service technicians. Several visits to the service department in the first 2 years, initially fobbed off with "car road tested, unable to reproduce sound" then "normal operational sound". Finally with the noise now at the point that it sounded like something was going to break or fall off I literally kidnapped one of their service advisors and drove him around all manner of roads for about 30 mins until he finally admitted he could hear a sound that did not appear to be consistent with normal operation. From there it started with adjustments to shock absorber casings (separate visits)!! or lubricating various bushings, each of which were sold to me as definitive solutions when picking the car up only to discover the sound back again a few kms down the road. Finally with about 3 months of the warranty remaining, and having threatened to book the car in every Friday (with loan car) until it was fixed they appear to have finally sorted it. Lithium grease to bearings on lower control arms, and a note in the system to replace control arms if noise recurs. Now 6 months out of warranty and maybe another 5000km on the clock and not a sound.
Hey forum readers and fellow VW fans, I was going to start a new thread about lower control arm bushes but decided to use this existing thread.
I had the same issue you guys are talking about, same response from dealer at servicing. The dealer applied some lanolin spray and the noise was gone until it rained. As my car is now out of warranty and the car was driving pretty poorly I decided to get a suspension specialist to look at it, I contacted Pedders as they do a $28 Brakes, Steering and Suspension Check. After having Pedders perform the check, they informed me the front right lower control arm bush at the rear had failed and the rear shocks were leaking (leaky shocks are a known issue but there is "some tolerances" that VW allow, not my issue at the moment because they did not show any faults in the test other than dampness at the seal.). Turns out the bush had been like that for some time and had been reported to VW during the warranty period. I spoke to the dealer about the outcome of the "$28 Brakes, Steering and Suspension Check" and what was wrong. The dealer said they could do a out of warranty good will claim since the issue is on the notes in the servicing history. They would just need a copy of the Pedders report, do their own investigation and place a claim to VWA. In one of my many questions I asked, would VW only replace the broken bush or would they replace all of them, the answer was "most likely only the one". With this information in hand I decided I didn’t want to mess around with one bush on 100k and the other new, so I had aftermarket bushes installed.
Some of the issues I noticed and some I was not aware off are until the bushes were fixed:- Creaking noise going in and out of driveways, especially when one arm was articulating when the other wasn't.
- Squeaking noise over speed humps.
- Poor traction/wheel stability over damaged bitumen, also being a diesel with lots of torque if it broke traction in the wet it would wheel tramp very harshly and would break traction quiet easily.
- Excessive play in the steering wheel, constant correction was need to go in a straight line. This affected ACC.
- When the bush finally gave way excessive tyre ware started to appear on the FR wheel.
- Finally there was generally a noisy ride throw out the car, would almost think the rear suspension was loose as well.
So the hunt for new LCA bushes started, After many years of reading car mags, somewhere in the back of my mind I wanted Whiteline parts, but after plenty of research I learnt that Superpro do a Polyurethane replacement bush as well and are easier to get and install. I called and spoke to several different mechanics and finally found someone who could replace all my LCA bushes at a reasonable rate and was close to home. I initially wanted to go for a full LCA replacement with bushes already fitted by Whiteline as these were cheaper than Superpro's LCA kit delivered and then there was the but "you don’t have the tools to do the work yourself silly". Turns out thanks to my DSG I need to undo all engine mounts and lift the engine so one bolt could clear 85mm and be removed.
If I had a manual gearbox, no worries mate just unbolt the LCA and install the new arms.
So what Superpro bushes did I have installed? I went for the SPF4178K - Control Arm Lower-Rear Bush Kit - Double Offset and the SPF4175K - Control Arm Lower-Front Bush Kit. The LCA rear bush kit came with castor correction. (The centre hole is off centre as opposed to OEM being set in the middle) Once the bushes were fitted I had new RE003's fitted and wheel alignment to square everything up. I would say replacing the OEM LCA bushes is a must. The car drives better, all the complained issues have gone and the car feels more in touch with the road and you can feel it get the power to the ground rather then it being absorbed in to the OEM bush or tramping its way down the road.
Thanks for reading and I hope this helps anyone else diagnosing their problem and for $28 the Pedders reports it was worth it.
