Hi all, i have been getting the dash lights going off on my Mk6 Gti, i finally got it scanned and it came up with the following faults.
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 13
Reset counter: 157
Mileage: 126358 km
Time Indication: 0
Date: 2011.11.20
Time: 11:54:22
Freeze Frame:
Count: 16391
Count: 0
Count: 12800
Count: 104
Count: 50964
Count: 65532
Count: 65273
Count: 512
01130 - ABS Operation
008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 157
Mileage: 126358 km
Time Indication: 0
Date: 2011.11.20
Time: 11:54:22
At first this was intermittent but has since become permanent.
Here's the strange bit, if i turn car on with foot on brake pedal i get no warnings until i release brake. Any ideas?
I have checked speed sensors. I've checked the fuses/ removed and cleaned the engine bay area fuse box.
I'm starting to lean towards replacing pump now unless there's another common issue i may have missed.
Cheers.
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 157
Mileage: 126358 km
Time Indication: 0
Date: 2011.11.20
Time: 11:54:22
Freeze Frame:
Count: 16391
Count: 0
Count: 12800
Count: 104
Count: 50964
Count: 65532
Count: 65273
Count: 512
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 157
Mileage: 126358 km
Time Indication: 0
Date: 2011.11.20
Time: 11:54:22
Cheers.
