I have a 2012 VW with a 1.4l twinchargers coupled with a 7 speed dsg. Over the last six months I would hear grating noises intermittently on gears 2 and 4 just after engaging them but saw no error codes in vcds. The noises were not consistently replicable. I tried a clutch adaptation and the procedure would successfully complete but the noises remained.
Sounded like a manual transmission where you changed gears without fully sinking the clutch pedal.
Anyways the sound has now disappeared from 2 and 4 but is waaays worse and only shows up in gear 3.
Gear 3 sometimes engages after a loud grating sound or sometimes never engages and the car then only allows even gears to be used till car is switched off and back on. I tried a clutch adaptation and the procedure halts on error 255/84 which in a document here says 3rd synchro timeout. I guess it is taking too long to move into a position and the system stops the adaptation. However the auto/trans in vcds shows no error.
I need help. Can anyone say if synchros are hard to replace? Any part numbers? Should I also replace the clutch pack one time since I'll be going into the gearbox?
I will be uploading a video so sound can be heard.
