2012 GTD. After the oil change and other checks I decided to have a go at the DSG oil change. What could possibly go wrong!
Youtubed and read up, decided to fill from the top after discovering I could get at the filter without removing anything. I ran the front up on the ramps, didn't think the angle would matter the way I was doing it.
All went well until after the fill, I discovered that the old plastic kitchen jug I used to measure the drained oil was smaller than a litre. with it I measured 4.95L came out and following advice I put in a little more for spillage and the filter.
To find out how much really came out I refilled the five empty DSG oil bottles with the dumped oil to find I could only get 4.3L worth in them (dibbled a bit). Concerned that I had over filled it, I carefully drained .55L out from the big bung. So I should have 5.2L - 0.55L = 4.65L in the gearbox while now suspecting there was about 4.5L drained out.
Questions
1. Is the GTD box a 4.5L model?
2. Am I ok after that trail of errors? If not what could I do?
3. If I level it, and take out the first big bung would excess oil drain out and solve any issue? (as described by the bottom filling method)
Questions
