Originally posted by Ozsko
View Post
Modern cars typically have 8 (if not more) ECUs all interconnected on a CANbus system. For many cars, if you try to swap one without coding it properly the others detect a problem and the immobiliser won't let the car run - see ECU Replacement - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com for an example. You get in an expensive contractor to re-code ECUs all the time?
Anyway, Solitaire came through with a loan car last Tuesday - I picked up a Polo Bluemotion with DSG on Wednesday morning. Impressively economical (almost as efficient as the GTD when driving gently) and enough power / throttle response to keep up with traffic. Not overly impressed by the response if the transmission if I asked it to go in the wrong gear, but the GTD probably only feels better because I typically drive it in manual mode and use the flappy paddles.
The Golf came back today.
The first couple of times I braked it pulled up hard - I guess the Polo has a higher pedal pressure, not that I noticed while I was driving it. I already miss the Polo's MFD & dash unit - I find it staggering how much better a current base model Polo is when compared to a Mk6 that (I thought) was a high-end model. All in all, I'd rather have the GTD - but (for various reasons - not just this experience) I may put it on the market soon.
