Here we go again. Don't mean to hijack this forum but seem to be having issue after issue.
Now the new intake manifold is in the car drives much better and with no rattle but I still have this low rpm stumble when I hold the rpm's at about 1200 rpm. Now I only get this when the clutch is pushed in, as soon as I release the clutch it runs smooth and from my previous threads this would cause the intake manifold to rattle like crazy.
This may not be linked but I've noticed on a few occasions now that when I roll up to lights or to stop and I press the clutch to put it in first for when the lights go green the car will have a little shake for a split second. When this happens and I still have the clutch pressed in it takes some great force to get it out of gear and once out it will not go back in gear unless I let go of the clutch and press it again. I have had this happen in 2nd gear too, I came to a stop left it in second, felt the car shake for a split second and then it took some force to get it out of 2nd and then it wouldn't go back into a gear until I released the clutch and pressed it again.
When driving I have no issues and it doesn't happen all the time.
Any advice would be appreciated.
If I can fix this all my issues will be gone.
Forgot to mention, if I leave it in 1st and not try and take it out the bite point of the clutch feels to be right at the bottom next to the floor rather than half way up the peddle like usual.
