Golf R wont start (SOLVED: Flat battery)
  • Golf R wont start (SOLVED: Flat battery)
    Help !
    Just went to start the car and it just "ticks" over without starting
    i get the following errors on the screen:
    1. "move selector lever to position p\n"
    2. a ping noise and "error: esp"
    the car is in P, it does the same in N
    Prior to this i have had no technical faults
    car is a 2011 golf r dsg with approx 40,000km's
    please help !
    let it sit for an hour and tried again with no luck
    im not 100% sure if its the battery as all the lights come on fine
    it has turned over a bit "slowly" recently compared to normal - could it just be a dead battery ?
    Sounds like a battery to me.
    Current: '11 Renault Megane RS 250 Cup Trophee - Manual - All Options - Stage 1 Bluefin
    Ex: '10 Nissan 370Z - Coupe - Manual
    Ex Ex: '10 VW Golf GTI - 3 Door - Manual - All Options - Stage 1 Bluefin
      What he said..
        Yep a new battery is what you need.
        The ticking is from the relays, the coil loads up and activate the armature but the battery cannot sustain the load as the starter is engaged, and the circuits open again. You hear a click as the contacts meet, this repeats very quickly.
        MK4 GTI - Sold
        MK5 Jetta Turbo - Sold
          'tis the season for new batteries.
          As it gets cooler, the battery performance drops off. If it was marginal before then it won't have the grunt to start now.
          Check the manufacture date on your battery. If you've got a 2011 car likely the battery was manufactured in 2010 so it's about the expected life of these types of things (4 years), though you'd always like it to last longer.
          - Tigger73's 125TSI Build
            thanks guys
            i was more worried about the errors it was throwing !
            i put it on a battery charger and it has started
            but ill definitly go by a new one today as i dont want to risk this happening when im away from home
            any recomendations on whats good for a golf r ?
            also, if its still under warranty, would the dealership replace this ?
              Originally posted by kam View Post
              thanks guys
              Good news that you got your car started.
              I don't think batteries are covered under the 3 year new car warranty. Likely only 12 months which I think is standard for the electrical equipment/accessories.
                What he said
                  Batteries are indeed covered under the 3 year warranty. If you call vw 24 h assist and they determine the battery needs replacing they will do it for on the spot. The new battery will have a 3 year warranty through the roadside assist company, in my case allianz.
                  MY 12 Golf GTI
                    excellent! thanks for that, its a good thing i didnt get a new battery today then
                      I will be surprised if they replace your battery under warranty, if it is within the first year maybe.. very happy if you get the thumbs up
                        Im not sure if they will cover it. I know my wifes Ford was not covered when the battery leaked and burnt through the wires for the abs pump!
                        Batteries are considered a consumable item by some manufacturers!
                        Sent from my GT-I9100
                        MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
                          I will be surprised if they don't. My battery died last month 2.5 years into warranty period. Call vw assist and had a new battery within an hour at no charge.
                          MY 12 Golf GTI
                            Same here - all covered under warranty :p
                            2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
                              My battery died couple of weeks ago. Just out of original warranty (I got extended). No questions asked, brand new battery replaced within a day free of charge.
