Bulb Out Warning light
  • Bulb Out Warning light
    Lighting system malfunction light has come on and I'm buggered if I can find anything wrong. There are so many little lights all around the cabin of the GTD, very difficult to find a fault.
    Hope all will be ok until next service in a couple of months so that dealer can sort it.
    re: Bulb Out Warning light
    Exterior lights?
      Checked them and they are all ok.
        LED's installed?....VDUB ..
        BRISBANE / GOLD COAST
          No LED"S. I've crawled around the car including brakelights, and all lights look ok. It's a pain putting up with warning light. Two hours from dealer.
            Are you referring to the 'bulb out' error light in the instrumentation? (A small yellow bulb icon.)
            When the car throws a bulb-out warning light, the 'errors/warnings/notices' page in the MFD will be available, and should give you a hint as to which light has blown. Just press the right arrow on your steering wheel to scroll through the MFD pages, till you see the notices page with the info you need.
              Thanks AdamD, you're a genius. It told me to check left reversing light, and bingo!
              Now I'll work out how to change it.
