Advice on DIY drivers mirror replacement
  • Advice on DIY drivers mirror replacement
    Hi all
    Does anyone have any knowledge on whether removing and replacing this mirror is an easy task?
    Reason being, VW are going to charge me a bomb for replacing it, I can feel it.
    Some bugger kicked my mirror in on australia day night and broke the swivel point.the casing and mirror look undamaged.
    Any advice for me?
    Car is booked in next Wednesday for service and I want to be prepared to DIY if the ring and say it will cost me $1000 to fix.
    Cheers guys
    Originally posted by russ83 View Post
    Hi all
    Any advice for me?
    Cheers guys
    In the manual I have it says remove the door trim and then prise the triangular speaker module off the door and presumably there will be some screws behind there that hold the mirror on.
    Thats how most work except havent had to remove door trim on cars I have worked on
      Hi all
      Any advice for me?
      Cheers guys
      Here is a DIY from golf.net.au for fitting puddle lights in the mirrors and it shows how to remove the door card and mirror in detail. Not a hard job if you take your time and care.
      DIY: Mirror (Puddle) Lights & Warning Door Lights
        Thanks hillbilly and brimway
        Sent from my iPad using Tapatalk HD
