Golf R flutter or compressor surge (vids included)
GOLF R - CW - MY10 - 3Dr - DSG - LEATHER - SUNROOF - RNS510 - DYNAUDIO - MDI - 19" Black Talladegas
APR STAGE 2+ - APR Divorced DP - VWR Intake - RS4 Fuel Valve - Neuspeed K04 Turbo Discharge Pipe - BSH Throttle Pipe - HPFP Fuel Pump - SPM FMIC - Hawk Ceramic PadsTags: None
Good vid!!! Losing boost 100% could be faulty valve?? Check faults. If you decide to replace valve and still there then possibly get it re-flashed back to standard and test. Something is wrong for sure you need to decide which way to find out.Last edited by grtuned; 14-06-2012, 09:09 PM.
Change back a gear, don't load such low revs or it will flutter (with any tune, even standard VW software) - remember you have a K04 on that car - The DSG makes it worse as it forces itself up gears (economy mode) where in a manual transmission you would never do it. An open intake makes it more audible (even on a stock car) - we can also reprogram your DSG so it's more pro active and will do a much better job at keeping you in the correct gear
The R will flutter under load, stock !Originally posted by buzuki View Postits in 'D' mode,
are you suggesting he drives it in manual mode to hide a tune issue? There is no reason it should flutter under load, as he is not backing off throttle.
I could make mine do it on demand
As much as I don't intend to defend APR, it happens, stock
The R and and D mode is stupid. Drive it.8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
You got me all curious about the DSG reprogram.Originally posted by Guy_H View PostChange back a gear, don't load such low revs or it will flutter (with any tune, even standard VW software) - remember you have a K04 on that car - The DSG makes it worse as it forces itself up gears (economy mode) where in a manual transmission you would never do it. An open intake makes it more audible (even on a stock car) - we can also reprogram your DSG so it's more pro active and will do a much better job at keeping you in the correct gear
Same here.Originally posted by John2204 View PostYou got me all curious about the DSG reprogram.
@ APR - Does a DSG tune come with your Stage 1 tune?Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
Looks like about 1800rpm.
How much boost are you expecting below 2k rpm?
Makes sense you are hearing the airflow whilst the diverter is open.
I don't see why the DSG would drop you into a gear where the revs are too low for decent power, the joys of trying to get economy from a performance vehicle?
Pretty sure DSG tuning is separate from ECU tuning.Last edited by noone; 16-06-2012, 11:39 AM.
Sure, maybe what I should have said is that engine mapping and DSG mapping are separate items. The ECU is just a computer. i have recently been battling through ECU issues in my GF's Peugeot 206 GTi, they were smart enough to break down the brains over 2 modules which need to be keyed alike to work. Can't just swap one out...
Exactly. Just interested in whether APR is now doing this (like a few others)Originally posted by Candyman View PostNo, a number of tuners can modify torque limiters in the DSG via the ECUGolf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
Can I just say that the issue was not there when I was on the stage 2 map with a Carbonio intake.GOLF R - CW - MY10 - 3Dr - DSG - LEATHER - SUNROOF - RNS510 - DYNAUDIO - MDI - 19" Black Talladegas
The Carbonio isn't really an intake, the stock air box assembly has baffles etc in it to help reduce the noise coming back through the system from the BOV/diverter valve etc, wacking on a pretty carbon piece to the front of it really isn't doing much (compared to complete replacement of the system with VWR/etc). So it may have been there but hidden away a bit (as Candyman says, under the right conditions he can get his stocker to do it, I guess the sound is just a bit more subtle with the stock air-box/filter assembly vs the complete intake replacement).---
Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
It look to me in the vid that during acceleration you would lose boost not a gear change loss in rpm. If your applying throttle you should have no boost loss if you do something's wrong!! No car flutters or loses boosts while accelerating. Never seen it on any stock standard golf old or new!!!
Sent from my iPhone using my fingers.
