Forum only readable to users
The server is being hammered again by crawlers, we are seeing tens of thousands of "users" online. Rather than give up and take the whole thing offline, I've switched it over so users must be logged in to even read the forum. I've also removed the ads completely once you're logged in since they are now basically worthless and annoying.
It's not ideal, but it keeps things online for now until I work out a better approach.
118 TSI loss of power
  • 118 TSI loss of power
    Any ideas on what could be the problem?
    Car - manual Golf 118 TSI 10MY 45,000km
    Problem - loss of power once trying to exceed 3000 rpm, all gears. Yellow engine/ECU light active on dash.
    No shuddering or loud bang. No previous signs of power failure.
    All fluid levels ok. No excess smoke or fuel usage. No strange sounds while driving.
    Inital thought supercharger or turbo gone as car still runs well (up to 3000 rpm) or softwear issue preventing reaching the rpm level.
    Don't have access to VagCom to conduct diagnostics.
    Welcome any educated guesses on this one.
    Last edited by Flipper Dog; 12-06-2012, 08:46 PM. Reason: corrected 300 rpm to 3000 rpm
    Flipper Dog
    Now - T-Roc R, Audi Q5
    I take it you mean 3000 RPM as they idle at 800.
    My guess if the revs are OK up to 3000RPM and then nothing afterwards is a blocked fuel filter or turbo issue. We had the reverse on ours. Wouldn't rev first up but would cruise at 110kph once you got it there. Was the flapper valve that switches the intake air from the supercharger and turbo. Could be that too. Best find someone with VCDS cable, or if still in warranty then take it to the dealer.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
      The same symptoms occured on my Skoda Octavia 1.8TSI. It kept going into some kind of limp mode if I tried to push the engine beyond 3000rpm. Turned out to be a failed high pressure fuel pump. Costed me $450 to replace as it was out of warranty by 6 months when it occured. Ouchhh....
        Problem ended up being a faulty fuze in the water pump - pump required replacing.
        Flipper Dog
          Are you sure the fuse was in the water pump?
