My no homo Raybans fit perfectly - note that there's a rubber lip you need to put the edge of the sunnies under, else it won't fit, even the aids ones on the first page.
Uses for that compartment in the roof console?
Useless buttons??? I have programmed the "i" button to call my wife's mobile and the "spanner" button to call VW Roadside Assist. Haven't found a way to program the "star" button yet.Originally posted by rossw View PostMy 90TSI has this little compartment in the roof console, just near the lights and the mic for the bluetooth and those useless little buttons.
Anyone found a use for this that doesn't involve dropping the contents in your lap on acceleration?Golf Mk6 103TDi (Dec 2011)
How did you reprogram those buttons?Originally posted by johnsonsabroad View PostUseless buttons??? I have programmed the "i" button to call my wife's mobile and the "spanner" button to call VW Roadside Assist. Haven't found a way to program the "star" button yet.Golf R 5 door United Grey | DSG | ACC | Leather | Bluetooth | 19" Talladega Black
The * button is to answer incoming calls? No idea why they have 2 of them. I have one near the eject button of the RNS and one on the roof WTF. Good idea though for the 'i' button though.Originally posted by johnsonsabroad View PostUseless buttons??? I have programmed the "i" button to call my wife's mobile and the "spanner" button to call VW Roadside Assist. Haven't found a way to program the "star" button yet.MY12 Golf R | 5 Dr | Candy White | DSG | 19"Black Talladegas | ACC | RNS510 SATNAV | Sunroof | RVC | BT | MDI
Ordered - 28/02/12 | Collected - 14/03/12
Probably, as they are all "call" type buttons. VW Assist, VW Care and the * button. The only one that works I am told is the * button, but someone says he has programmed another button which is handy, probably through the MFD setup menus.Originally posted by Scratchyratface View PostAre the buttons near the sunglasses holder only present if you have premium bluetooth or something? I don't have the buttons at all on my MY11.5 GTI
If you don't have Bluetooth, you can't call anyone.MY12 Golf R | 5 Dr | Candy White | DSG | 19"Black Talladegas | ACC | RNS510 SATNAV | Sunroof | RVC | BT | MDI
Your missing out. The factory Bluetooth is sensational. Does and has everything. Can control through the steering wheel buttons on the MFD as well, no need to use the touch screen RNS. Get it for your next car. I think that Bluetooth function in this day and age is a must. Was for me.MY12 Golf R | 5 Dr | Candy White | DSG | 19"Black Talladegas | ACC | RNS510 SATNAV | Sunroof | RVC | BT | MDI
You need to program the numbers using VCDS and a VAG-COM cable The numbers are pre-programmed to dial Europe numbers!Originally posted by m_f View PostHow did you reprogram those buttons?
Anyway if you have access to VCDS and cable you can prorgam as follows:
Under the Telephone module (77 from memory) goto "Adaption" this displays a long list of options. At the bottom of the drop down list the are four phone number fields. There are two for each button, the "i" button and the spanner button.
Jimmy from the VWWatercooled forum provided the information below that worked for me:
The Service/Breakdown coding requires 7 bytes which are entered as their raw numeric values. So for VW roadside I entered 18 00 63 71 81 00 00 (note padding with 0's for the last two bytes). The Information number requires 8 bytes, again pad with 0's for the extra bytes.
Program the buttons for any number you like. I found that all four numbers need to be entered for it to work.
Once programmed, you press and hold the button for 2 seconds and the it dials the number. The MFD displays the hold for 2 second message, then it displays either INFO CALL or SERVICE CALL (or something to that effect)
Good luck. BTW using the VCDS is up to you, there is always risk associated with programming your car via VCDS. If you choose to use the information above, you do so at your own risk.
Cheers Brett.Golf Mk6 103TDi (Dec 2011)
Yeah unfortunately I thought Bluetooth was Bluetooth, had no idea that there were so many 'versions' of it and the dealer failed to mention it (haven't forgotten that!). Have thought about upgrading it along with lots of other ideas, just short on cash!Originally posted by San Gimignano R View PostYour missing out. The factory Bluetooth is sensational. Does and has everything. Can control through the steering wheel buttons on the MFD as well, no need to use the touch screen RNS. Get it for your next car. I think that Bluetooth function in this day and age is a must. Was for me.
BMW Z4 (2019)
Audi TT quattro (2015), s-line in Nano Grey - sold
