Just Fitted GTI Steering Wheel to base Golf - Problems
  • Just Fitted GTI Steering Wheel to base Golf - Problems
    H1,
    Fitted a brand new GTI wheel to my MY12 Mk6 Golf that had a basic plastic wheel.
    The Airbags were identical - but I used the new one, but could have used either.
    The problem I now have is that Horn does not work and 5 of the dash lights stay on.
    Anyone else had this problem ?
    thanks
    Digger
    No problems with my install but my golf is a comfortline. You sure the airbags are identical? Do the multifunction buttons work?
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
      Update,
      Went for a drive and turned the wheel all the way to the left and then all the way to the right. All warning lights now gone off.
      Only left with the Horn not working now.
      Is the horn part of the Airbag module ? If so, I could swap back to the old Airbag as it did fit.
      As it is a 77TSI - I would have to change control module to get the buttons to work - so I didin't bother with that.
      thanks
      Digger
        It could be the module. My original airbag was completely different to the GTI airbag.
        MY20 Golf GTI TCR
          Does your Horn work ?
            Yep! Everything works like it should
            MY20 Golf GTI TCR
              lol I don't think I've even tried to use my horn since (I did think I should test it after retrofitting but never had an appropriate opportunity). That said, last week I had over 5 people come close to side-swiping me due to not looking when changing lanes, but between avoiding a collision and downshifting I never got around to using the horn (plus I don't like the sound of the Golf's horn).
              I'll try and test it later on.
              Also keep in mind that the horn doesn't work w/o ignition, in case that's how you were testing. As far as the control module goes, didn't that come with your new wheel?
              Audi A3
                No, the control module is the SWCM which is a separate part.
                Will try turning the ignition on for the Horn, assumed it would work without, every other car I had it did.
                  This oversight was discussed (argued) extensively here about a year ago when one member was sitting in his car and watching someone about to reverse into it, but the horn wouldn't work.
                  Nice pick up Ryan_R.
                    The SWCM on the new models is actually part of the slip ring which forms the base of the control stalks. I retrofit a MFSW onto my 77TSI and had to upgrade the SWCM as part of the process (which also enabled me to install a cruise control stalk). Then Vag Com the wheel to get the buttons, lights, horn to work. All in all probably the best upgrade to my 77.
                    Dave
                    New Ride: MY19 PW R Special Edition
                    Past: MY12 5dr CW Golf GTI Manual
                      Hey Dave,
                      Do you know if I would be able to just use an upgraded slip ring for my 77TSI Golf to get MFSW buttons working? I heard conflicting reports that I may also need to upgrade the stalks as the 77TSI base model uses the wiper stalk buttons to access the MFD menu... Using my existing stalks may cause conflict in programming to get the MFSW MFD menu access to work?? The 90TSI upwards add cruise control and minus the MFD buttons on the wiper stalk. Anyone confirm this is true or not?
                      Cheers,
                      AL
                        Mate,
                        I bought the Cruise Control package from Kufatec (which came with a new slip ring and new stalks - even though the MFD controls were still present) and it worked fine once the coding was done correctly.
                        I ended up with MFD Controls on the steering wheel AND on the control stalk and had 0 problems, the MFD could be controlled from both the stalk and wheel as normal.
                        Dave
                          Thanks mate,
                          I may try my luck and just order a highline slip ring module only as I actually dont need cruise control function and see if it can be programmed for all the MFSW buttons to work.
                          Cheers,
                          AL
                            Thanks Dave,
                            Yeah, I worked that one out, and have purchased the new parts including the combined SWCM/Cruise Control / Wiper Stalk.
                            Just waiting on getting a new Vagcom cable as the first one I got was faulty.
                            Digger
                              Thanks Dave,
                              Digger
                              Yep, this is the best way IMO. Also the coding for the steering wheel wasn't that straight forward...to get it to work i HAD to insert the codes (the workshop i think its called you know whatever they are that tell you who did the coding). It would not accept the CORRECT coding without populating those fields.
                              I just put in 12345
