I had a light fault pop up on the dash this afternoon and a prompt to check just about every light on the car. Thought I had a blown trafficator bulb as when I indicate left or right, the ticking and lights were quite rapid.
When I got home, all bulbs were working?????
Scanned with the VCDS and it indicated a fault with the central electronics
Interestingly, it fixed itself when I took the car out about an hour later. Has anyone experienced this or have a clue about what is causing this?
Sunday,25,September,2011,14:07:11:26677
VCDS Version: Beta 11.8.0 (x64)
Data version: 20110831
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W469134
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 44180A38982518C044080080140081E443510088436D896064 8000000000
Shop #: WSC 01357 011 00200
VCID: EDFF84398A88
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 27110 21 0501
Coding: 009F95
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 111208 05 54 0402
Coding: 0330AD
24 Faults Found:
02382 - Sensor for Light Detection (G399)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Mileage: 60720 km
Time Indication: 0
Date: 2027.14.18
Time: 12:13:23
Freeze Frame:
Term 15 On
Voltage: 14.55 V
ON
ON
Term 50 Off
OFF
OFF
00061 - Footwell Lights
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 5
Fault Frequency: 6
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:45
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
Term 50 Off
OFF
OFF
01701 - Dimmer for Interior Lighting
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 5
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:45
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
Term 50 Off
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 208
Mileage: 60833 km
Time Indication: 0
Date: 2027.14.23
Time: 08:55:48
Freeze Frame:
Term 15 On
Voltage: 14.60 V
ON
ON
Term 50 Off
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 18
Reset counter: 208
Mileage: 60833 km
Time Indication: 0
Date: 2027.14.23
Time: 08:55:48
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 208
Mileage: 60833 km
Time Indication: 0
Date: 2027.14.23
Time: 08:55:48
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61978 km
Time Indication: 0
Date: 2028.14.22
Time: 12:50:36
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61974 km
Time Indication: 0
Date: 2028.14.22
Time: 12:44:08
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61978 km
Time Indication: 0
Date: 2028.14.22
Time: 12:50:36
01505 - Bulb for Blinkers; Rear Right (M
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61974 km
Time Indication: 0
Date: 2028.14.22
Time: 12:44:08
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
02395 - Parking Light Right Front (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:02
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:02
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:02
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
02745 - Bulb for Daytime Running Light; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:15
Chassis Type: 1K0
Revision: 00020000
VCID: EDFF84398A88
Coding: 009F95
Coding: 0330AD
24 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Mileage: 60720 km
Time Indication: 0
Date: 2027.14.18
Time: 12:13:23
Freeze Frame:
Term 15 On
Voltage: 14.55 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:45
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:45
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 208
Mileage: 60833 km
Time Indication: 0
Date: 2027.14.23
Time: 08:55:48
Freeze Frame:
Term 15 On
Voltage: 14.60 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 18
Reset counter: 208
Mileage: 60833 km
Time Indication: 0
Date: 2027.14.23
Time: 08:55:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 208
Mileage: 60833 km
Time Indication: 0
Date: 2027.14.23
Time: 08:55:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61978 km
Time Indication: 0
Date: 2028.14.22
Time: 12:50:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61974 km
Time Indication: 0
Date: 2028.14.22
Time: 12:44:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61978 km
Time Indication: 0
Date: 2028.14.22
Time: 12:50:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 208
Mileage: 61974 km
Time Indication: 0
Date: 2028.14.22
Time: 12:44:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:35:59
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:03
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 208
Mileage: 61968 km
Time Indication: 0
Date: 2028.14.22
Time: 12:36:15
