Collected a wombat at ~ 100kph last Fri night. Smashed the front left plastic bumper, impacted the LH front wheel and took out the lower engine cover. Bent the horn bracket and that's about it visually. Pulled up nice and straight with TCS, Electronic steering & TMPS warning lights all on. (Nice to know my TMPS mod works in anger). Fortunately no obvious damage to headlight or the metal body work. Poor blighter left some of his coat wedged between the tyre and rim of the rear left tyre on exit.
Had a quick look to ensure car was still driveable and limped the 10 kms home in the dark after defouling the lower engine cover which was dragging on the road. The TCS and Steering lights cleared within a couple of minutes and the TMPS light cleared a bit later.
Car was fine to drive, however the steering alignment was unsurprisingly out, with it pulling to the left & me having to hold the steering wheel offset 2" to the right to drive straight. If I let go of the wheel the car would veer off the road.
Pulled the VCDS messages and the main one was a momentary impluasible steering angle of -19 degrees! You get that when you hit a wombat at 100kph I guess.
What is really neat is how the Electronic power steering subsequntly worked. Over the weekend I used the car sparingly driving only a few kms at low speed on country roads. During this period the steering was as I decribed above - in that I had to hold in a right hand force to track straight.
At the end of the weekend I set off the 200km back to MELB. Within about 10 minutes of driving at highway speeds on
sealed roads the electronic power steering adapted to the alignment error and allowed the car to track dead straight again with hands off the wheel and no lateral trim force required by me. Albeit with the wheel still offset 2" to the right as had been the case all weekend. This is how the erwin self study guides describes the electronic steering sytem works with crosswinds - clever stuff. Obviously if I was to keep driving the car indefinitely in this bent configuration it will scrub the tyres out. I explained this adaptive system to my local VW service dept last year when I had an alignment issue and they had no idea this was how it worked! The point to note here is that the system can trim out lateral errors by using the yaw sensors and mask bad steering alignment.
Anyway, car is getting mended now. Hopefully they can realign the steering and nothing more serious is bent in the front end. Could have been a lot worse.
