Dull thump thump thump which increases in frequency with wheel speed. Very noticeable at low speeds e.g. 40kph and also there (at higher frequency) as speed rises. No vibration through steering wheel or anywhere else. Seems worse when boot loaded. Purchased new 09 build GTI 5-door DSG now 30,000 kms. This noise has been there for ages. Did not have any such noise with Mk 5 GTI over 60,000kms. Dealer confirms definately tyre noise, one or more "feathered". Not apparant to me on uneducated look and feel. Standard rims and original Bridgestones wearing well and evenly. Am I going mad??????
Noisy tyres.........or something else????
Originally posted by J Walter View PostDull thump thump thump which increases in frequency with wheel speed. Very noticeable at low speeds e.g. 40kph and also there (at higher frequency) as speed rises. No vibration through steering wheel or anywhere else. Seems worse when boot loaded. Purchased new 09 build GTI 5-door DSG now 30,000 kms. This noise has been there for ages. Did not have any such noise with Mk 5 GTI over 60,000kms. Dealer confirms definately tyre noise, one or more "feathered". Not apparant to me on uneducated look and feel. Standard rims and original Bridgestones wearing well and evenly. Am I going mad??????
Are yours 17"?sigpic
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
If it's not tyre related, it sounds like a wheel bearing...
Surely not on such a new car though?
Ozram, I have used gordon leven in penrith area... Might be a bit far for you though2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
it will definatelly be the tyres, ive got 225/40/18 tyres and they went after about 35-40k done on them. sound was very annoying, very noticable at slow speeds especially when slowing down and was a constant whine at highway speed. chaged the tyres the other day and noise has gone completely, and yes it was due to 'feathering' - get a wheel alignment when you change your tyres, im going to get one any day now - just trying to find somwhere cheap - quoted at $120 by Pedders atm :| (all 4 wheels).
sound i got was more of a deep whine though at slow speed and higher pitched whine at higher speed.MY18 MKII Tiguan 162TSI R-Line | Deep Black | DAP | Sunroof
For Sale - MY11.5 MKVI 3DR Golf GTI | Pearl Black | Manual | Sunroof | Dark Tint | Dynaudio | MDI | Bluetooth | Bi-Xennons
Mods | R Tails | P3 Gauge | LED Interior Conversion | Lakin Plates | VW Racing Springs | 19" RAYS 57Motorsport G07EX
My wheel alignment is OK and tracking and tyre wear is good, and the wheels are standard. Thanks for the info guys. I am now persuaded that it is the feathered tyres and won't be fixed until I replace them. Any suggestions for replacement tyre brands? You may be wasting your money on a wheel alignment Ozram. If you can put some other wheels/tyres on and see if the noise goes away. My dealer said he did that with mine and the noise went, but I was not sure I believed him. Maybe it was the truth!!!!
the noise wont go away with only the wheel alignment done alone, worn tires will need to be replaced also. getting the wheel alignment done will just prevent the same happening to your new set of tires. my tyres were worn only on the inner loop, rest of tread was fine! thats my understanding of it anywayLast edited by MiiLos; 03-03-2011, 11:28 AM.MY18 MKII Tiguan 162TSI R-Line | Deep Black | DAP | Sunroof
Originally posted by J Walter View PostI am now persuaded that it is the feathered tyres and won't be fixed until I replace them. Any suggestions for replacement tyre brands?2008 MkV Volkswagen Golf R32 DSG
Originally posted by J Walter View PostMy wheel alignment is OK !!!!
Try swapping the tyres left to right so that the direction of rotation changes. Even better if you can go front to rear at the same time.
Increase the pressures to at least 36psi - 38psi is better still. Give it a few thousand km & you might find the noise will reduce a bit.
I find Bridgestones to be generally quite resistant to saw-toothing & Dunlops are usually shockers. Either way, I always prefer to pay a bit extra & fit Michelin.
For ongoing maintenance, you should be cross-rotating your tyres every 10,000-15,000km.carandimage The place where Off-Topic is On-Topic
Originally posted by brad View PostTry swapping the tyres left to right so that the direction of rotation changes.
At least on my last 3 VW's, cross-rotation of the tyres is not possible with the standard tyres
The dealer confirmed the wheel alignment was fine at the recent 30,000km service and I have no tracking or pulling (left or right) issues and there is minimal scrubbing of the inside tyre edges. The pressures are usually 38 psi, but I will try to isolate the offending tyre(s) and have a good look for something like a stuck bolt or screw. I like the idea of Michelins upon replacement.
Originally posted by Corey_R View PostI'm not sure what model Golf you have, or what model tyres you have, but you'd want to make sure that your tyres are not directional before doing this! Many performance tyres these days are only designed for left OR right use, and cannot be swapped to the other side.
The upper spec Golfs had which directionals? Dunlop Sport Maxx & the non-A RE050?
Thanks for pointing it out. I assumed that most people would have a clue but then again, you do see a lot of directionals that are rolling the wrong waycarandimage The place where Off-Topic is On-Topic
Originally posted by J Walter View PostCross rotating? I thought that was a No No...........
My preference is to leave the drive tyre rotating the same direction & cross the tyre of the lazy axle. eg: On an FWD put the fronts direct to rear; the LR to the RF; RR to LF. Not quite as simple on an AWD but generally most AWD are front bias so you can do the same pattern.
Kumho Tire USA, Inc.
Tire Tech Information - Tire Rotation Instructions
Tire-saving Tips: Tire Care & Buying Guide: Michelin Tires
SOUTHSIDE TIRE Automotive Tire Rotationcarandimage The place where Off-Topic is On-Topic
