What do you guys feel about this? I have APR 2+ GTI that's about to go in for a 60k service and also will fit in a BSH race catch can. Do you think its necessary for a full upper engine clean. I know you can use a spray can upper engine cleaner but im not sure if it will clean the hard deposits of carbon.
Carbon Buildup..
Originally posted by Parky View PostWhat do you guys feel about this? I have APR 2+ GTI that's about to go in for a 60k service and also will fit in a BSH race catch can. Do you think its necessary for a full upper engine clean. I know you can use a spray can upper engine cleaner but im not sure if it will clean the hard deposits of carbon.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Seb in Girraween does full strip down engine cleans. Apparently the only way to make sure all the gunk is removed.
Contact details found here:
Originally posted by Sir_GTI View PostTransporter, what product would you suggest to do the clean?
Motorcrfat R16 - from Ford dealer or Motortraders.
Amsoil Powerfoam (similar to Motorcraft R16) from Amsoil dealer in your state.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostWURTH Intake system cleaner - it could be harder to get, you will need to find the WURTH distributor. I could help you, if you were in Adelaide.
Thanks Transporter, I will have a look and see what I can find.
Are these just a spray type cleaner?
Just trying to figure out if it will be an easy job every 15k, or if it will require some downtime.MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
Amsoil Powerfoam (similar to Motorcraft R16) from Amsoil dealer in your state.Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
Originally posted by break View PostAny reason for those over something more readily available like the Subaru branded 'Upper Engine Cleaner' product?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Parky View PostWill these spray can upper engine cleaners actually work with hardened deposits of carbon ?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostSubaru upper engine cleaner is the same as Ford Motorcraft R16, both made by Bars Leaks. Ford will be cheaper and if you could get Amsoil PowerFoam you get more product for less.Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
