As a driver and car owner you have the duties and responsibilities for maintaining your car to keep it safely on the road. One of of the duties is to check engine oil on regular basis which can vary, but good practice is to check the engine oil level when you buy fuel or every 500km. Car must be parked on the level surface and engine off for at least 5minutes. Oil level should read between low and full mark on the dipstick. Keeping the oil level at max is good practice since the lubricating oil also cools the engine. Constantly low oil levels will shorten the life of the oil and the engine.
					"A" Max. level "C" Low level
						 I'm a bit of a hoarder
