Originally posted by MurphyTheElf
View Post
Does your dual zone climate control over compensate for sunlight?
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostThat has a lot to do with safety; so you don't run out of oxygen in cabin.Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
Touareg V8 TDI R-Line, White .Arrived 11 July.
I can't see the sun loading sensors so i assume they are measuring the dash temperature from underneath. If I knew where they were then it would be simple to place some inconspicuous material to reduce the sun loading in that area.2018 Tiguan 110TSI Comfortline + DAP
Since when does the "Off" setting on a climate control system mean that all air is cutoff? Isn't it exactly the same as setting the temp control to full cold (ie no heat) and turning the a/c and fan off on a "normal" system.
Yes, however on some occasions one wishes to have windows down, sunroof open and vents shut off.
Actually... facing the vents away from your face/body may solve alot of the A/C problems people are facing (pardon the pun).
You dont usually sit in a room or office with the A/C blowing on you. The air coming out of the car vents is WAY colder than that temp set on the dial. Mix that with the wind chill of moving air then I can understand why some people could find the climate control erratic. Its trying to cool the entire cabin, not just the person the air is blowing on.
Originally posted by pologti18t View PostActually... facing the vents away from your face/body may solve alot of the A/C problems people are facing (pardon the pun).
The only vent I turn away from me is the one on the right - otherwise my right hand on the wheel slowly starts to freeze
I logged data on the drive home today for various air temperatures and sun intensities measured by the climatronic unit including the air-con compressor torque (temperatures plotted here).
http://dl.dropbox.com/u/14542234/LOG...11-581-601.pdf
The set temperature was 23 deg on both channels and the measured cabin temp was relatively stable, sitting between 24 and 26 degrees with the air temperature coming out of the front vents varying between 6 and 26 degrees. It is was interesting to learn that the cabin temp is measured using an infra-red detector, so it is measuring the temperature of the interior surfaces rather than the air temperature which is an important difference to many other HVAC systems (I've run a quick experiment on the sensor which is visible on the front panel of the climatronic system and it appears to be sensitive to both cabin air and surface temperature). The system very active with constant adjustments and the air temp from both the front and foot vents differed by up to 10 degrees right to left.
I've decided the best position for the front vents is up and away from me, given they can push out 6deg air at short notice!.2018 Tiguan 110TSI Comfortline + DAP
Originally posted by MurphyTheElf View Post- On hot days, I need to set the control to 25 degrees so it doesn't continue to blast cold air in my face. Vice versa on cold days.
- When entering a very hot cabin, it is far too conservative in blasting the cabin with cold air. The fan is never set to maximum, so I do it manually.
- If the unit is set to Off, then nothing should come out of the vent. I always get the climate du jour filtering through the vents when I do this. But I can't close the vent with the unit off.
Allowing some amount of outside air into the cabin when the fan's switched off is how every car I've ever owned has behaved, and it seems quite odd that you'd want anything else. I do find that I've had the temperature set slightly lower in winter than in summer, but mainly that's due to often wearing a jumper and possibly a jacket as well when it's cold outside.
You dont usually sit in a room or office with the A/C blowing on you. The air coming out of the car vents is WAY colder than that temp set on the dial. Mix that with the wind chill of moving air then I can understand why some people could find the climate control erratic. Its trying to cool the entire cabin, not just the person the air is blowing on.Golf 118 TSI DSG, white with sports pack.
For those that want to experiment, I've located the sensors in the cabin and found descriptions for them in a couple of VW Self Study Programmes.
The 'unventilated interior temperature sensor' is integral with the Climatronic control panel and is the small protuberance located in the middle of the shiny black strip underneath the top row of buttons. It measures surface temperature, unit temperature and sunlight penetration (Ref SSP-318, pg 69).
The 'sunlight penetration photosensor' is flush with the top of the dash and sits between the RH and LH windscreen defrost vents. It measures the intensity and direction of sunlight penetration (Ref SSP-271, pg 59).2018 Tiguan 110TSI Comfortline + DAP
Originally posted by MurphyTheElf View PostCalling the air conditioning unit in the Golf "climate control" is optimistic at best. Extreme temperatures variations aside, we should be able to set the control to a comfortable level and have it self-adjust. Here are some of the problems I have:
MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
MY 2010 Skoda Scout Manual Silver -traded
Originally posted by prise View PostFor those that want to experiment, I've located the sensors in the cabin and found descriptions for them in a couple of VW Self Study Programmes.
Thanks very much for that. I think the sunlight penetration sensor might be a little too sensitive in some cases. Will try some experiementing with the sensors in my car to see if it affects the aircon response.
Which self study guide did you get the info from? Can you provide a link please?
Thanks again.
Cheers,
Cam.MkVI GTI, Tornado Red, Leather, Tint, 17" wheels, Black Euro plates.
The Mk 6 Golf SSP's arent out in the public domain but fortunately the system design has been re-used from the Mk 5 and many of the components have been used previously.
Here's where you can find the guides I referenced. VolksPage.Net - Technik - SSP - Self Study Program VAG
VW's erwin site will have the Mk 6 self study program material if you're prepared to pay the access fee.2018 Tiguan 110TSI Comfortline + DAP
