The control rod runs horizontally just below the where the exhaust manifold attaches to the head. You can see it from underneath (when the car is on a hoist or stands) by looking up the back of the engine block. It's a 6mm (approx) dia rod from the actuator to the turbo. The rod would be 20 - 25cm long. Not sure yet if the noise is from the wastegate on the turbo or the actuator. It could even be the rod itself resonating causing the wastegate or actuator to vibrate and make the noise. It would be a real bugger to get to. Probably would need to remove the exhaust manifold and turbo to do the job properly. I couldn't see if there is a brace or mount from the turbo to the actuator. Will have another look soon.
Cheers,
Cam
Cheers,
Cam
