I remember reading somewhere that the 103 TDI engine wasn't hugely heavier than the petrol versions. In some other makes, the diesel is so much heavier that diesels are nowhere near as balanced on the road as the petrol versions (take the Subaru outback for example) - so when looking at the owners manual (I have a 103 TDI) - I noticed that some 103 TDI's have a CBAB code and others (like mine - a CFFB code) - so I'm thinking - why use 2 codes for the same engine - and on page 122 there is a glimmer of an answer. The CFFB 103 TDI 6 speed manual golf weighs 1351 kg, while the exact same common rail 103 TDI with particulate filter CBAB weighs 1374 kg. Where have those 23 kg gone? - Purely for interest sake - does anyone know what they have done to the engine to shed 23 kg? - I' cannot find anything doing a google search.
1 of 2
2 of 2
Engine weight 103 TDI
Are there any other differences between the two besides engine/particulate filter? Things like brakes, alternator, battery etc. which could account for the extra weight?
I know currently VW quote 50kg difference in kerb weight between the diesel and eqivalent petrol...
Regards,
- Anthony.VW Tiguan 110TSI Life | Tungsten Silver
The CFFB is pretty new to the scene. The CBAB (or kebab, as us techies were calling it at last year's Golf 6 training), has been around since mid '08, from memory. I'm unaware of the differences between the two at this stage.
VW are always trying to shed weight off their engines. It would be hard to pin-point where, as they seem to be fairly thorough.'07 Transporter 1.9 TDI
'01 Beetle 2.0
The weight of the 118 TSI (whole car) is around 1310 kg, so the 103 TDI (in CFFB spec) is about 40 odd kg heavier overall. As for the filter - this is what I'm asking - even though the CBAB diesel engine is exactly the same spec - with supposedly all the same additional filters and common rail system etc - then the question is, what have they done? - I am going to guess that the CBAB engine weighs about 280 to 300 kg - so a 23 kg reduction (given that the rest of the car should be identical) - is about a 7-8% reduction in engine weight. Thus, did they just make it 7-8% thinner? - did they replace cast iron with lighter alloy in large parts of the engine? - did they indeed remove something they considered unimportant from the previous engine? - this is what I am interested to know.
this CFFB spec engine is obviously so new that the owners manual I have, dated November 2009 does not have CO2 emission data for it, nor does it have Fuel consumption values, which suggests the fuel readings currently on vehicles are still based on the CBAB engine. - interestingly here too - it states the CBAB engine with 6 speed manual as 4.9 L/100km combined. Must be something about Australian conditions that bump it up to 5.3?
So this is a potential, expensive but marginal upgrade for 2.0 TDI 103kW owners, as an engine swap in a few years?Bizi's Jetta TDI: Blue Graphite w. factory leather & tint, plus + Enkei Racing NT03+M + Yokohama S Drive 18s, Koni FSD, Neuspeed coils, GTI RSB + brakes, InPro mirrors, VW navi, Modshack. Come for a drive through the twisties on Saturdaze.
Check out Winedriving forum/news for driving trips and wine tips.
I took a trip to Mudgee in a Golf 103 TDI and noticed that my Garmin GPS measured our speed at a lower value than the MFD measured. The difference varied but the Garmin usually had a value 5km lower than shown on the dash.I presume this would affect the calculated fuel consumption.
My two cents worth
MW103DSG
Originally posted by NovaArtist View PostThe weight of the 118 TSI (whole car) is around 1310 kg, so the 103 TDI (in CFFB spec) is about 40 odd kg heavier overall. As for the filter - this is what I'm asking - even though the CBAB diesel engine is exactly the same spec - with supposedly all the same additional filters and common rail system etc - then the question is, what have they done? - I am going to guess that the CBAB engine weighs about 280 to 300 kg - so a 23 kg reduction (given that the rest of the car should be identical) - is about a 7-8% reduction in engine weight. Thus, did they just make it 7-8% thinner? - did they replace cast iron with lighter alloy in large parts of the engine? - did they indeed remove something they considered unimportant from the previous engine? - this is what I am interested to know.
Originally posted by MW103DSG View PostI took a trip to Mudgee in a Golf 103 TDI and noticed that my Garmin GPS measured our speed at a lower value than the MFD measured. The difference varied but the Garmin usually had a value 5km lower than shown on the dash.I presume this would affect the calculated fuel consumption.
My two cents worth
MW103DSGYou know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
My two cents worth
MW103DSG
Same in europe. Same with Commodore, Same with most other makes. (Also brings service points closer!)
Apparently Toyota is one of the very few who indicate speed "as it is"MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
Speed and Distance
Yep agree with both posts, will check whether distance travelled is more accurate than indicated speed.
I always found that Toyotas were spot on with speed. I have owned two corollas and a vienta and found that unlike the most Europeans they indicated speed pretty accurately.
cheers
You may find that the speedo is out by more than 4%. In each VW I've owned (MK4 Polo GTI and MKV Golf GTI), when the speedo is reading 100, the car is actually doing 93. So that's 7% out. It is exactly 7% out at any speed.
Originally posted by coreying View PostYou may find that the speedo is out by more than 4%. In each VW I've owned (MK4 Polo GTI and MKV Golf GTI), when the speedo is reading 100, the car is actually doing 93. So that's 7% out. It is exactly 7% out at any speed.
Must be pretty common over a wide range of makes as sitting on 118 indicated you tend to catch and pass a lot of good citizens driving at their 110 indicated speeds.
Only seem to be passed frequently by red p platers at this speed.Last edited by Highlander; 15-07-2010, 12:21 AM.You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
Originally posted by coreying View PostYou may find that the speedo is out by more than 4%. In each VW I've owned (MK4 Polo GTI and MKV Golf GTI), when the speedo is reading 100, the car is actually doing 93. So that's 7% out. It is exactly 7% out at any speed.Golf 118 TSI DSG, white with sports pack.
I'm set to recieve a second blocked DPF off a MKV GT TDI, so I'll weight it before I start surgery on it. No way it's 10+kgs different though!2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Test Slow
