Originally posted by Idle
View Post
Speedo Inaccurate
Originally posted by coreying View Post..it's not 10% out.... it's 7% at most. If you upgrade to a car with 18 or 19" wheels, then it will come up to around 5%
...THAT is why VW have to put their cars to 7% under, as they are available with 18" and 19" wheel upgrades, it wouldn't be so easy to take your VW with a DSG down to the local mechanic and get them to change a 'gear' in the DSG to correct the error from going from 17" to 19" wheels and still having the '4km error' at 100kmph that you mention!
I do not believe "VW put their cars to 7% under, as they are available with 18" and 19" wheel upgrades".
Some misconceptions creeping in I reckon. Remember all the speed/distance measuring equipment cares about is the circumferance of the tyre. It has no interest in wheel sizes. You cannot assume that changing wheel sizes changes tyre circumference.
VW publish a list of 36 tyres that can be fitted to my 118. In reality this breaks down to 6 actual tyre sizes ranging from 15" to 18" rims. Changing from a 15" wheel and tyre combo to an approved 18" setup will change the outside circumference of the tyre by 0.003% (read zero). This will have miniscule/minute/near zero effect on your Speedos or odometer. Unless your concerned about 3km in 100,000
If you stick to VW's recommended tyre and wheel size combos you should not see ANY appreciable change to the odometer or the intentional speedo error when you change configurations. So I do not think the intentional speedo overread is there to cater for upsizing rims. I reckon it is there because for whatever reason VAG have decided, agreed or been mandated to implement it.
The distance multipliers values are listed as being vehicle specific and not wheel/tyre combo specific. ie 7 if for a Golf and 2 for a Polo and another for a Skoda, Seat and so on. They are not segregated into tyre/wheel size combos in any way.
My take on it is that VW arranged things so that the odometer will be accurately correct and the speedos will accurately over read by the intentional error whenever recommeneded wheel/tyre combos are fitted. Assuming of course you do not screw with the distance multiplier which "exists primarily to accommodate different transmission types with different gear ratios between the the driveshafts and vehicle speed sensor." I say accurately with tongue in cheek as it is German after all & it will do whatever it does accurately.
Hey Maverick are you going to correct the 3 mistakes/errors on your idea of how the speedo works page or are you still not convinced?Originally posted by Maverick View Post
If you do so, while correcting 1)"Adjusting the distance impulse number does not alter the odometer, the distance impulse number is an error that is introduced for the speedometer needle." You might want to also correct 2)the assertion that the blank ---speed warning screen will show Can Bus speed. Might have been the case with a MK5 but with MK6 all this does is sets/displays current digital speedo speed as WNG speed and is nothing to do with Can Bus, which when viewed from VagCom is a totally different figure. Finally 3) I would not be so quick to write of the blokes impression that screwing with the dm can alter your indicated fuel consumption. I'd reckon if you set your ODO to overread by 8%, like I clearly showed can be done then the calclulated l/100 will get skewed in proportion. No reason to expect it would not. Appreciate it will in no way effect true consumption.
What do you reckon my chances of seeing some changes are fellas. Buckleys I reckon
Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
I didn't assume... I went to the tyre size calculators etc and found that changing from 225/45 R17 (VW's GTI standard) to 235/35 R19 (VW's R option) gives 1.98% change in rolling circumference. There are many people who change to to the 235/35 R19 on their GTI's etc.Originally posted by logger View PostYou cannot assume that changing wheel sizes changes tyre circumference.
Oh, and I don't think that is the ONLY reason VW underread by 7% - it's just one of the many.
Edit: Further to that, the actual change using VW options on the specific models:
GTI: 225/45 R17 to 225/40 R18 = 0.46%
R: 225/40 R18 to 235/35 R19 = 1.53%
So again - you're pretty much never going to exceed a 2% effect on the speedo by changing your wheels and sticking to the VW recommendations, and 2% is nowhere near 7% obviously, but changing wheels certainly does have an effect on the reported speed.
If you want to get even MORE specific, you can also often find the actual rolling circumference of the tyre from each tyre manufacturer, because even the same 'size' tyres can have different rolling circumferences between brands and even models of the same brand - this can also add/remove a few points to the figures above.Last edited by Corey_R; 17-02-2010, 03:32 PM.
The Mark 6 has a different cluster to the Mark 5 and the blank speed warning speed displays a different speed to the Mark 6 which can display the speed (unlike the Mark 5 which can't).Originally posted by logger View PostHey Maverick are you going to correct the 3 mistakes/errors on your idea of how the speedo works page or are you still not convinced?
The testing that I performed including repeated trips over the same distances that showed no change to the odometer. I will be doing some further testing but it appears that operation has changed for the Mark 6.
You mean the post where he claims that the change affects the engine operation, stops the cruise control from working in all gears except sixth and claims that fuel consumption sky rockets (no mention of the MFD reading) just that fuel consumption sky rockets. I clearly stated that this doesn't change fuel consumption.Finally 3) I would not be so quick to write of the blokes impression that screwing with the dm can alter your indicated fuel consumption. I'd reckon if you set your ODO to overread by 8%, like I clearly showed can be done then the calclulated l/100 will get skewed in proportion. No reason to expect it would not. Appreciate it will in no way effect true consumption.
Clearly the aim of your post was not to correct any possibly incorrect information.
website: www.my-gti.com
Yes fair enough - I will happily concede that point. Changing wheels can have, but does not have to have an effect on the reported speed. Like you say the worst case 2% is trivial compared to the over read of 6%. I was wrong when I said "If you stick to VW's recommended tyre and wheel size combos you should not see ANY appreciable change to the odometer or the intentional speedo error when you change configurations." This only applies to the TSI118 recommended tyre list.Originally posted by coreying View PostI didn't assume... I went to the tyre size calculators etc and found that changing from 225/45 R17 (VW's GTI standard) to 235/35 R19 (VW's R option) gives 1.98% change in rolling circumference. There are many people who change to to the 235/35 R19 on their GTI's etc.
Quite right -that is in fact what I did to establish the 0.003% difference between 225/40R18 & 195/65R15 profiles. Diameter 635 vs 637. So if you stick to TSI118 recommended tyres your wont see the anything like the differences you calculated for the GTI or R as you have shown.Originally posted by coreying View Post..If you want to get even MORE specific, you can also often find the actual rolling circumference of the tyre from each tyre manufacturer.
Thats a tongue twister. Had to read it twice.... Funny thing is that it wasOriginally posted by MaverickClearly the aim of your post was not to correct any possibly incorrect information.
Oh well "I will be doing some further testing.." and "possibly incorrect information" is an excellent start. So Thanks.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
I assume the speedo is electronic? If so there has to be a way (for someone who knows what they are doing) to rewrite the code so that the speedo displays the same speed as the ECU is seeing?
Anyone? Maybe we could get one of the aftermarket tuners to add some code to the remap?
Its here!
Beaker - that's what Maverick and Logger have been discussing in previous pages, changing settings in the VAGCOM software. But it seems that the only adjustment is some type of multiplier which affects several values at once.
I don't believe that ECU reflashes change the code which handles the speed - but logger or Guy would be better people to comment on that.
I've tried tweaking the Distance Impulse Number because on the R with 19s I'm doing 94-95kmh when the needle and digital speedo are showing 100kmh. I want to know exactly what I am doing when I look down, not some mathematical acrobatics. The best I could do was set it to Distance Impulse Number 8 and the country to Australia and now I'm only about 3kmh out.
Cheers,
SteveLast edited by Corey_R; 05-05-2011, 10:34 AM. Reason: Edited out non-speedo comments after move from VCDS thread
Keep in mind now that you've done that, that your entire trip meter is now wrong, including fuel consumption and Odometer. The car KNOWS that it's doing 93/94km/h, but tells you that you're doing 100km/h because it's required to do that by law. If you were to do 100km/h and then reset your trip meter, it would then tell you CORRECTLY that you're averaging 93/94km/h. Now that you've changed those figures, it'll give you incorrect information, incorrect fuel consumption, incorrect range til empty, etc etc.Originally posted by SteveK View PostI've also tried tweaking the Distance Impulse Number because on the R with 19s I'm doing 94-95kmh when the needle and digital speedo are showing 100kmh. I want to know exactly what I am doing when I look down, not some mathematical acrobatics. The best I could do was set it to Distance Impulse Number 8 and the country to Australia and now I'm only about 3kmh out.
Good info Corey...Originally posted by Corey_R View PostKeep in mind now that you've done that, that your entire trip meter is now wrong, including fuel consumption and Odometer. The car KNOWS that it's doing 93/94km/h, but tells you that you're doing 100km/h because it's required to do that by law. If you were to do 100km/h and then reset your trip meter, it would then tell you CORRECTLY that you're averaging 93/94km/h. Now that you've changed those figures, it'll give you incorrect information, incorrect fuel consumption, incorrect range til empty, etc etc.
Stevie, I think you may want to change it back man?
Are you sure about that Corey? Not having a go, just trying to understand your thinking. I've worked with guys to do tunes on various local cars and adjusted speedos via electronics to correct deficiencies and my understand is that you are just adjusting the reading from the rolling tyre to the speedo. From there the CPU will use that data to correctly calculate average speeds and fuel usage etc. It's all based on data lines and if the speedo data is incorrect, from the wheels, not what is displayed, then YES the rest of your data is wrong. When compared to various other GPS based speedometers the car is definitely out and after the correction it is closer. I still don't see how that is bad?Originally posted by Corey_R View PostKeep in mind now that you've done that, that your entire trip meter is now wrong, including fuel consumption and Odometer. The car KNOWS that it's doing 93/94km/h, but tells you that you're doing 100km/h because it's required to do that by law. If you were to do 100km/h and then reset your trip meter, it would then tell you CORRECTLY that you're averaging 93/94km/h. Now that you've changed those figures, it'll give you incorrect information, incorrect fuel consumption, incorrect range til empty, etc etc.
Cheers,
Steve
I'm not speaking for Corey here, but I believe the point he's making is that your car's speedometer is actually accurate, with respect to the speed the car believes you're travelling. However, a degree of error is introduced into the instrumentation, to ensure the car is road-legal (and this error value is different for the analogue and digital speed readouts). Distance-based systems (so, odometer, trip meter, and fuel consumption based on distance travelled) all rely on the actual road speed - not the number you see on the dial.Originally posted by SteveK View PostWhen compared to various other GPS based speedometers the car is definitely out and after the correction it is closer. I still don't see how that is bad?
The settings you're adjusting with VCDS are presumably there to make allowances for different fitment wheels and tyres, to ensure the car itself gets the speed right. By changing these, you're not actually reducing the amount of error in the instrumentation, but rather throwing off the car's perception of true speed.Last edited by AdamD; 04-05-2011, 11:13 PM.2008 MkV Volkswagen Golf R32 DSG
I think I understand what is being said but I think the interpretation is being lost on me.Originally posted by AdamD View PostI'm not speaking for Corey here, but I believe the point he's making is that your car's speedometer is actually accurate, with respect to the speed the car believes you're travelling. However, a degree of error is introduced into the instrumentation, to ensure the car is road-legal (and this error value is actually different for the analogue and digital speed readouts). Distance-based calculations based on a measurement of vehicle speed (so, odometer, trip meter, and therefore also fuel consumption based on distance travelled) are all based on the actual road speed.
There is a contradiction here. You state that changing the VCDS to account for different tyre sizes is what the feature is for but by doing so you change perceived speed of the car.Originally posted by AdamD View PostThe settings you're adjusting with VCDS are presumably there to make allowances for different fitment wheels and tyres, to ensure the car itself gets the speed right. By changing these, you're not actually reducing the amount of error in the instrumentation, but rather throwing off the car's perception of true speed.
This is my point exactly. Changing the wheels/tyres will have a physical effect on the perceived speed (what is displayed on the speedo). So you adjust the VCDS to counter for that. Is that not the same as saying "The perceived speed of the speedo is not accurate so you adjust the CVDS to counter for that".
I understand that all cars are created with a set 'speed' rating so that by using the correct size tyres and gear ratios etc, the correct speed will be displayed on the cars dashboard. I know that is what is being mentioned here and I totally agree that this is the case. The point I'm stating is that mathematically, if the dashboard is showing 100kmh on the analog needle and 100kmh on the digital display but is showing 94/95kmh on an external metering device then there is a multiplication factor introduced somewhere along the line that has affected the display.
I've "assumed" that this "Distance Impulse Number" is the 'correction factor' that adjusts this. But if my understanding of the responses in this thread is correct, does this DIN value affect the 'VW agreed value of speed' for the car? If that is so, then I am mistaken. And if so, how is any correction made? Having a car going slower than what is being shown is not what I am used to. My previous car was tack perfect, 100kmh was 100kmh was 100kmh. Every external measuring device was spot on. Overhead speedo checkers, dead on.
Thanks again for helping me understand this.
Cheers,
Steve
So, think of it this way: if you have standard wheels and tyres on your car, then, all else being equal, your car knows how fast it's travelling, exactly. That accurate perception of the speed is used to calculate the distance travelled and everything else based on that - so, if you drive at precisely 100km/h for 1 hour, your trip meter will read 100km.Originally posted by SteveK View PostThere is a contradiction here. You state that changing the VCDS to account for different tyre sizes is what the feature is for but by doing so you change perceived speed of the car.
However, your car lies to you about how fast you're travelling. It knows you're doing 100km/h. But it tells you (via speedo) that you're doing 105km/h (or 107, or even 110), so you'll slow down, and stay under the limit. The only error in this whole equation (and it's an intentional one) is in the instrument you're reading. Australian law requires that speedos must read 100% accurate or overestimate up to 10%, but must not underestimate.
What you want is to have an instrument that shows you a (more) accurate representation of how fast you're actually going. So you use VCDS to alter the car's settings to achieve this. Trouble is, rather than having reduced the error margin in the instrument itself (the amount by which the car is lying to you), you're actually making the car think it's going slower than it really is. The nett result is that, yes, the instrument will read a lower speed, but the odometer/etc will underestimate how far you've driven - throwing out its calculations.
So, I believe what Corey is saying is that the Distance Impulse Number (DIN) isn't the fudge factor in the instrument (the gauge you read), but is rather used to affect the car's understanding of the road speed - to allow for larger wheels, worn tyres, etc. I don't believe we fully understand the relationship between the DIN and the road speed measurement, or the DIN and the instrument-indicated speed, but AFAIK it relates more closely to the former than the latter. If it relates to the former at all, it will have a flow-on effect on the latter. User Logger has done some extensive experimentation with this - might be worth searching out his posts to see what he concluded. From memory, there's no hard and fast way to get a 100% accurate reading out of the speedo, and any adjustment to the DIN can potentially have an adverse impact on your distance measurement.Originally posted by SteveK View PostI've "assumed" that this "Distance Impulse Number" is the 'correction factor' that adjusts this. But if my understanding of the responses in this thread is correct, does this DIN value affect the 'VW agreed value of speed' for the car? If that is so, then I am mistaken. And if so, how is any correction made? Having a car going slower than what is being shown is not what I am used to. My previous car was tack perfect, 100kmh was 100kmh was 100kmh. Every external measuring device was spot on. Overhead speedo checkers, dead on.
My suggestion: use an accurate GPS to calculate the error in your instrumentation (digital and analogue) at various speeds. I know in my car, for instance, that 60km/h reads as 63km/h, and 80km/h shows as 85. I got used to sticking to a particular indicated speed pretty quickly. If you hate that idea, keep a portable GPS in the car, and rely on that for a satellite-verified speed reading.
No worries - hope it's making sense!Originally posted by SteveK View PostThanks again for helping me understand this.Last edited by AdamD; 05-05-2011, 12:01 AM.2008 MkV Volkswagen Golf R32 DSG
