Mk6 LED Taillights
  • This is the kind of thing I mean..
    True, could be an issue with some CECMs. Constant flicker is just the frame rate issue with the video (will look solid in real life). it's the flashing and slow 'loading' that would worry me!
    2013 GTI Candy White | DSG | Leather | Sunroof | Privacy Tint | OSIR Carbon Fibre Mirror Caps | Gloss Black Emblems | Gloss Black GTC GT-CX 18x8.5 Wheels |
    • I put LED indicators front and rear in my R and see this initialization also when starting, it is just the car sending a short pulse to check for bulb out, no harm.
      • Originally posted by tonymy01 View Post
        Why doesn't it happen in cars that come with LEDs from the factory?
        • Originally posted by Rawcpoppa View Post
          Because they don't do a bulb check with LED lamps. The pulse sent will briefly go through an incandescent filament without being seen, but a LED takes just mA current to both operate, and lights up nearly instantly compared to incandescent/halogen filament type globes. I assume bulb out type tests aren't done with LEDS since they should in theory last a lifetime...(certainly if manufactured properly won't be prone to blowing from vibrations etc like filament globes).
          • If anyone is game for for OEM looking replicas but won't break the bank, apparently you can get these for AU$350 express shipped from China.
            For VOLKSWAGEN VW GOLF 6 LED TAIL LAMP, Rear Bumper Rear Lights MK6 (Fits MK6)-in Rear Lights from Automobiles & Motorcycles on Aliexpress.com
            I've only used Aliexpress.com for clothing and has never failed me yet. Didn't realise I could get car parts too. There's a few other shops that sell visually similar LED tails too. Worth checking out I think.
            I take photos | threetwoone.com.au
            I also drive a MY16 R
            • Originally posted by GL118 View Post
              I took the plunge and ordered a set from Euro Car Upgrades (JKU.com.au) as they stocked genuine OEM retrofit parts. I was really pleased with the customer service, the expedient shipping (QLD to NSW) and fast installation and coding service offered.
              I have been gazing longingly at these from JKU.
              Did you get the:
              Central Electric Module 1K0937087R - version High R20 / GTI
              Body Control Module - Central Electrics Control Module
              From JKU too? Does the R20/GTI replace the standard golf part without any problems?
              MY17 Arteon | 206TSI R-Line | Manganese Grey Metallic | Front window tint 35% | Stage 1: ECU Racing Line tune, DSG APR tune, R600 intake bundle |
              MY12 GOLF Mk6 103TDI Comfortline | Shark Blue | RD Technik Stage 1 Tune | DSG Tune | RNS510 | Highline RVC | Window tint 35% | GTI steering wheel |
              See build: http://www.vwwatercooled.com.au/foru...ild-99394.html
              • Originally posted by Golf Girl View Post
                Did you get the:
                You shouldn't need a change to your CECM if you're running a 2012 Golf. Check out this link:
                Mk6 LED Taillights - Page 27
                • Originally posted by AdamD View Post
                  Good info thanks.
                  But why on jku's website does it say:
                  "BCM CECM module has to be highline (part # ending in 087)"
                  genuine VW Golf R OEM LED Taillights retrofit kit RHD 5K0945093AG Euro Car Upgrades
                  and on the CECM part:
                  Compatible with :
                  - LED DRL
                  - LED Tail Lights
                  - LED License Plate
                  - Bi-Xenon Headlights
                  genuine VW BCM CECM Highline - LED Xenon R20 - 1K0937087R Euro Car Upgrades
                  Just a little confused now.
                    If you can wait a couple of weeks we can do a full scan of your car and then you'll know exactly what control modules etc you have.
                    Otherwise you could take a punt that your control module will work and only upgrade it if you can't get yours to work.
                    Welcome to the world of VW electronics. This is the bit where everyone takes a guess at what features the VW engineers have put into what version of each module and people find out by trial and error as to what parts are needed when they go to do upgrades on their cars.
                    If you can find someone that has done the upgrade on a similar spec/age car you should be fairly right.
                    Not sure what happens with the "older" CECM whether you just get bulb out warnings on the dash or if the lights don't work at all. If you just get warnings I'd take the risk and then if you get errors coming up you can change the CECM later on to get rid of the faults. Either way you'll need to change some of the coding.
                    - Tigger73's 125TSI Build
                      But why on jku's website does it say: "BCM CECM module has to be highline (part # ending in 087)"
                      JKU highlights the required module because not all Golfs (overseas particularly; low-spec models) are fitted with this part. However I'm 99.9% sure you'll have a highline CECM and compatible revision already. We've done this on dozens of cars that I know of (including TDIs), and I have personally coded several Golfs and GTIs. Wait till you can get a VCDS scan of your car so we can verify the part and revision numbers.
                      Bulb-out warning only.
                        JKU highlights the required module because not all Golfs (overseas particularly; low-spec models) are fitted with this part. However I'm 99.9% sure you'll have a highline CECM and compatible revision already. We've done this on dozens of cars that I know of (including TDIs), and I have personally coded several Golfs and GTIs. Wait till you can get a VCDS scan of your car so we can verify the part and revision numbers..
                        Ah ok that makes sense. I think I'll do the scan first before deciding what I need.
                        Will work on the RVC before doing at the tail lights.
                        • Could anyone suggest where I could find an OEM set for a decent price? I have checked Jku and Boldsport as mentioned throughout the thread, but both are near $1k shipped which is too steep for me. I really am against a set of replicas such as CT autoparts ($400~), but the price difference is too big.
                          Also, if anyone does have replicas, could you please advise me on the quality and reliability of the set.
                          Thanks!
                          • Led mk6 rear light code
                            Hi,
                            Need help on getting the code for my LED rear's i have recently fitted to my GTI, so i can get the warning light to go off. Where do i start to find out getting this information? i thought these lights were play n play? they are OEM and not copy's.
                            Thanks
                            John
                            • This should be a helpful link.
                              • Originally posted by Vexrz View Post
                                Thanks!
                                Same problem here, maybe a group buy could be next step. I had a look at some replicas on the internet, there is a good brand out there but it is hit and miss in regards, to installation, they can have a huge gap under the light and I dont really want to risk it and I think Genuine is the best way to go if you are pretty anal about the little things.
