so has anyone replaced white globes on the MK6 for headlights?i was thinknig about philips diamond vision..any comments?
Headlight / DRL / Foglight / Park light bulb replacement
VW will no doubt have them.Originally posted by alphabeatsco View PostOops. So anyone know where to get h15 bulbs?
In terms of replacing the MK6 TSI 118, factory fit - I too would be interested in a compatible bulb that improves on the H15 . unlike others, I am not at all fussed by yellowness of the 19w DRLs (I have disabled mine). Am after more grunt from the 60W main beams though, for country driving. I find them pretty average. So if someone eventually finds something compatible PLS sing out.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
It depends on how you do it. What do you plan on doing? Blue tinted lights give less light so unless you want to see less you should go for a bulb that actually offers better performance like the Osram NightBreaker.Originally posted by alphabeatsco View Postsorrie, i actually meant white /blue DRL bulbs.
i also want to ask, if i replace the parkers , plate lights and headlights bulbs.
is it going to cause an error on the dash? i know some euro cars do that.website: www.my-gti.com
was on ebay but that saller doesnt have them any more...Originally posted by alphabeatsco View PostNAU: you mentioned that u changed both bulbs...
where did u find the h15 bulbs?His: Golf6 5door GTI DSG Carbon Sunroof MDI and 18" Drag rims + sticker that gives extra horse power
Hers: Skoda Kodiaq Tech/Lux pack and sunroof
I'm going out on a limb here, only cause I'm from an electrical background, but I suspect the LED lighting does not draw enough current to make the car think the (conventional) light bulb is working. It thinks the bulb is blown.
Regards,
BrianCurrent drive:2016 Golf GTI 40 Years in Pure White
No, you will need to build resistors into it to make sure the blown globe light isn't illuminated on your dash. The system sends a small electrical current that is complete if all globes are operational. If a tail light globe blows for example that signal is broken and the warning light comes on.
Check Mav's site here for better info.
Upgrading the number plate lights to LED on the Volkswagen Golf, Jetta, GTI, R32, Rabbit and Passat | my-gti.comsigpic
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
Mate - no offense, but if you don't understand basic electronics and the information in the link that Ozram posted, then maybe you shouldn't be mucking around with the electronics on your car! You don't want to cause an issue which creates a problem which won't be covered under warranty....
