I have the sports pack with 17" Bridgestone Potenzas. Car came with 51psi which is the max recommended on the tyre. Fuel cap suggests 230 2,3(33psi?). Do I assume is for 16" standard wheels or does it apply to the 17" as well? If not then what should be the pressure?
Thanks!
__________________
Ex - MkVI Golf 118TSI Lemon owner!
erm... you might have read wrong... 50PSI is something you would put into a bicycle tyre, and not a car tyre. ~33PSi sounds just about right for 17" with people filling it to 30PSI for a balance between comfort and grip.
Checked the pressure again and it was at 50!! I have not looked that the tyres since taking delivery. Pretty average to have them delivered like that.....
I have just dropped to 38 and will see how it feels.....excuse my ignorance on the subject Umai Naa but why 38 vs 33???
__________________
not sure why the exact figure of 38psi, but basically, with more pressure, you have less of the tyre in contact with the road, as compared to a tyre with less pressure. as long as the tyres are rated to take that pressure, then there's no harm there, though your ride would be pretty harsh.
p.s. not even going to ask why they delivered your car with 50PSI in the tyres
...They don't even roll off the boat with that much in them!
Unless someone/thing forgot to let them down after seating the beads. But unlikely for all four tyres I guess. In any case pre-delivery should have pickedthis up.
Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Did you check your tire pressure in the day? (heat?) air expands in heat so it would give a higher reading than normal
i was just doing a quick calculation and an increase of temperature from 20C to 40C will account for approximately 6% increase in pressure so to get 50PSI, we would be looking at an approximate increase of 500+ degrees C
Hi all
Just wondering what is the right /optimum tyre pressure for 16" 205/55?
I got a mk6 118tsi.
I was checking the existing tyre pressure from a gas station to see if I had to fill in, but was surprised to see when it showed 34 or 35 Psi reading! I believe the last time, it was filled by VW dealer/service centre. I then lowered it to 32 psi.
Hi all
I got a mk6 118tsi.
What does the manual say?
Higher pressure you can reduce fuel consumption at the expense of "less grip" with a lower pressure.
Lower pressure you walk around on the sidewall (being high profile 205/55s) and induce increased wear.
