Forum only readable to users
The server is being hammered again by crawlers, we are seeing tens of thousands of "users" online. Rather than give up and take the whole thing offline, I've switched it over so users must be logged in to even read the forum. I've also removed the ads completely once you're logged in since they are now basically worthless and annoying.
It's not ideal, but it keeps things online for now until I work out a better approach.
Automatic Dimming interior rear-view mirror
  • Automatic Dimming interior rear-view mirror
    Hi All,
    Mine automatic dimming interior rear-view mirror seems does not work sometimes. I mean, sometimes I can see the head light of the rear car is green shown on the mirror but sometimes does not and as normal bright.
    When I was picking up my car, the dealer told me that I can adjust the level of dimming. How can I adjust that? I can't find such information from the user manual.
    Many Thanks
    Platin Grey Skoda Octavia Scout Premium
    if it was available it should be in the manual. i thought the mirror does it on its own depending upon how close the car is behind you.
      the mirror is just on or off.
      Mine has never let normal light through. Take it back to the service department as it's warranty.
      _Dru.
      <VW Passat R36 Sedan>
        I've had that happen a few times on mine.
        Generally I just turn it off then on, then give it a few minutes and it progressively darkens down.
          hmm mine seems to work fine, maybe take it to the dealer to have a look at it
          Volkswagen Golf MK7 R Wagon Wolfsburg Edition Lapiz Blue
            well, I have tested it today under sunshine.
            I put my finger at back sensor (facing windscreen), the mirror does dim. However, if I covered my finger at front sensor (facing me), the mirror seems does not dim. Is that normal?
              Yes. The sensor facing the windscreen detects whether there is daylight or not. By covering it, the mirror thought it was night time therefore automatically dimmed the mirror a little. The sensor facing you senses whether there is bright light or not -- ie:the headlights from the cars behind are reflecting and shining into your eyes. When it senses the extra light it dims the mirror further. If you cover the windscreen side with your finger and shine a torch onto the mirror side sensor facing you, you should be able to see what I mean.
                After sunset I went out had a driving. I think it still does not work 100%.
                If I covering the back sensor, the mirror will be darker after a few seconds. But it will back to normal after a few seconds being darker.
                Maybe need to take to dealer have a look.
                  Good luck. Mine has never worked - yet the dealer tells me it's normal. Hence I've disable the bl**dy thing.
                  2018 Golf GTI, Manual - gone.
                  2017 Golf 110tsi Trendline, manual (gone - gladly)
                  2007 Golf GTI, Manual, (gone - sadly)
                  1978 Golf GLS; 1972 Superbug, (memories)
                    If you put your finger over it and it goes darker its working. It doesn't work in the daytime unless its overcast or the light behind you is extremely bright. It goes back to normal when you tested it because you're letting more ambient light in bt taking your finger off - that' s normal.
                    Check the angle of your mirror ? clean the sensor?
                    MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
                    MY 2010 Skoda Scout Manual Silver -traded
                      The angle should not be a problem as nothing is blocking the view. I will try to clean the sensor tomorrow. Just use wet cloth?
                        To be honest, that is simply a suggestion. I could not guarantee that it is effective or even the right thing to do so I can't say how it should be done. I think you'll find that it is working OK and according to its own rules not to how we think it should work. Same goes for rain sensing wipers. Everyone has a different opinion as to whether they work properly or not simply because they have different expectations.
                          No, I think if there's a bright light, it should dim. My Mark V and Mark VI always dimmed based on the light intensity. Ox's problem sounds like the sensor doesn't react at all.
                          I would take it into the workshop to be looked at (I know it's a pain but worth it).
                          Skoda Octavia Mk3
                          (sold) Golf Mark 6 Comfortline 118
                          (sold) Golf Mark5 Comfortline Manual 2.0 FSI
                            Guess what, it works now.....
                            Well, actually it works all the time, but I just realized that when I arrived Sydney.
                            I thought it did not work just because there are only a few cars on Canberra's road.......which means there were not enough light came through due to only 2-3 cars behind me most time during the night in Canberra.
                            And finally, the problem has been solved in front of hundreds cars in Sydney.........
                            Thank you everyone.
                              We aim to please...
