Mirror dipping / Reverse mirror tilt
  • #31
    The R comes standard with sensors but not park assist.
    There may still be hope through the dealer, not sure. Good luck
    • #32
      as per VW Australia brochure:
      "Parking distance sensors, front and rear
      Optical Parking System (OPS) in radio display
      Automatic kerb function when reversing, passenger’s Side exterior mirror Parking distance sensors, OPS and automatic kerb function are features supplied with the Park Assist option. These features are standard for Golf R however Park Assist functionality is not available"
      sigpic MY16 GTI 40
      • #33
        Hehe.. it's funny every time this comes up, how many posts it takes to get to the actual answer.
        Thanks MIRSAD
        • #34
          Thanks MIRSAD
          Funny how the answer was given a few times already
          Re the VW PDF, it contains errors as well. Go figure.
          • #35
            Yep, in several other threads
            • #36
              Search function on this forum doesnt work very well and sticky threads are not that well done
              Not surprising questions get asked multiple times....
              • #37
                • #38
                  Yeah, I know. Like how ****ing rediculous is it that when you search on "dipping" and tell it to show you "posts" that you don't get a valid result until the 2nd post down... man, that sucks.
                  Seriously dude, if you have a good suggestion, please inform the world. Otherwise, please realise the fact that some people just don't bother to do a search, or look at the index. Cheers
                  • #39
                    I use it as well
                    Wish the drivers side mirror had more adjustment outwards though
                    Mine is at the max but still not far enough for optimum
                    You can.. either move the seat forward or tilt the seat forward .. problem soved
                    • #40
                      When is VW going to give buyers folding ext mirrors and illuminate the ignition switch?
                      2012 MK6 GOLF R. DSG. RISING BLUE
                      • #41
                        Actually. That's something I agree with. I have the same issue with the drivers side mirror not adjusting enough.... although, for my particualr seat position, the issue is more that the outer edge of the drivers side mirror housing obscures too much and so there is a limit to the useful maximum adjustment available... but that's another issue
                        The folding external mirrors is an option on many models overseas, but not here. So I don't think it's a pressing issue for them. Australia doesn't typically have thin alleys to traverse.... I don't know.
                        As for the illumination of the ignition switch. I'd say that you'll get push button start before that...
                        • #42
                          i still think its a matter of learning to reverse properly..
                          90 TSI 1.4T
                          • #43
                            There is no option
                            You select the left mirror whilst key is in the on position and stationary, move it down to the area you want to view and then turn key off and then every time you select reverse with the selector on the left mirror it will move down automatically
                            When you drive off, move selector off left and it will return to normal
                            That is how mine works on my R which doesn't have park assist
                            MY12, DSG, leather. Otherwise base model
                            Save yourself a couple of kilojoules of effort!
                            After setting up your two preferred positions of the left mirror, you don't have to play around with the mirror selector every time you want to reverse/cease reversing - if you did, it would be incentive enough to learn to learn the width of your car! Mine was almost fully automatic. Oddly, the only time I had to muck around with the switch was when I had the mirror heaters on (the switch at 12 o'clock) - the mirror wouldn't drop until I turned the heat off. In any other position, the mirror would auto-drop in reverse and auto-correct when moving off. I assume everyone else has found the same?
                            MY11 R, no park assist.
                            • #44
                              Tried again this morning (at service dept)
                              Same issue so perhaps something not right in my R ?
                              They are looking into it now
                              It isn't about learning the width of the car
                              For me, it is just having a feature of the car work as expected. I may or may not use it from time to time.
                              • #45
                                Apologies, I know this question has been posted before but there seemed to be some uncertainty every time.
                                Conclusion: The car needs to be fitted with parking sensors from the factory. For every model except the R park assist needs to be optioned.
                                Okay we get it... Apparently two posts saying that you're an amazing parker wasn't enough and you felt the need for another. Here, have a lolly
