Originally posted by triode12
View Post
TSI squeal noise problem on acceleration
Faint high pitch whine??!!Originally posted by triode12 View PostMy GT doesn't sqeal, squeak, creak or squark from the engine area. But with the windows down, radio off and in a quiet area, I can hear the faint high pitch whine of the SC. And on spirited acceleraton, I do hear the turbo blow off.
I regularly hear a commodore near my house (vs or vr) with an aftermarket sc fitted- makes a HORRIBLY LOUD (note caps for increase effect?) whine. I know the little roots jobby fitted to the 1.4 is no scorcher...... But "faint" just doesnt cut it.
Maybe you need to put the boot in a bit more? Or drive down a narrow alley (Newtown has plenty) or tunnel with no traffic around and have a proper listen to your engine and it's lovely sound..
I sometimes park in my garage and leave the car running just so I can hear the exhaust reverberating/echoing off the closed roller door.Current - MY16 2015 Octavia VRS Wagon 220 tsi DSG Corrida Red, tech, Leather, 18" black
SOLD - 2008 United Grey GT Sport TSI DSG
LOL - I don't doubt it. Is this before or after removal of the soundproofing?Originally posted by MariusGT View PostFaint high pitch whine??!!
I seriously can't really detect it working unless it is under those conditions I mentioned earlier. Driving any faster, I'd only be hearing the sound of the rush of the wind buffeting the seat belt and tyre/road noise.
You wouldn't want to leave the engine on too long in your enclosed garage...!
I haven't removed the soundproofing..
i don't mean you need to drive fast to hear it - quite the contrary. It's MOST audible in 1st gear acceleration off the mark when the sc is cranking to lift revs. due to relative speed and low wind noise etc (as you mentioned) the sc SHOULD be quite audible. especially since you drive a GT and not the slightly detuned 118. hmmmm... boot it in 1st and get back to me!
carport. rolladoor plus one more wall and a roof - the rest is all tropical garden. i'm actually feeding my ferns etc some Co2!!
Mine is FAINT and extremely difficult, if not impossible to hear. Even though your GT is detuned to 125kw as compared to mine at~ 150kw
Perhaps the supercharger is more audible in the cabin in the older MK5 BLG engine as compared to the more recent MK6 CAV installation.
By the way, you will get a markedly longer SC run time in 3rd with a DSG6 or 4th in a DSG7 than in 1st. In Manual mode slow right up to about 20 K's and then plant it in the tallest gear you can. Because in the tall gear the revs are far slower to rise to 2500/3500rpm range where the SC cuts out. You need to get a high torque demand with relatively slow rev increase. In 1st the revs usually climb so quick that the SC will only run momentarily.
You absolutely sure it is the SC and not the turbo you are hearing?Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Yep- I know the difference between the two sounds. Used to own a '97 club spec evo wrx.. The whoosh whistle is a marked difference to the mechanical whine of a sc. In the rear lane behind my house (access to carport) the alley is VERY narrow and the sound is echoed loudly straight back to cabin with windows down.
I understand the sc will engage for longer at a tall gear / low speed- the reason I suggested the low speed accel in 1st off the mark is the lack of other sound interference: wind buffet etc.
Also just as the sc has finished doing it's bit raising the revs I can hear it whine a split second extra after lifting off the gas. Then engine returns to normal sound resonance at idle. All this is happening in my rear lane as I approach garage.
Are you listening for the whine at low speed with windows DOWN?Current - MY16 2015 Octavia VRS Wagon 220 tsi DSG Corrida Red, tech, Leather, 18" black
Yes crawling at 700rpm with windows down. Plant the foot. Even applying a handful of handbrake to load things up. Mine is FAINT and extremely difficult to hear. You can just discern a rumble for about a second. On my installation you would not describe it as a whine at all. Must be better sound damped than your GT for whatever reason.Originally posted by MariusGT View PostYep- I know the difference between the two sounds. ...
Are you listening for the whine at low speed with windows DOWN?Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Mine is an MY07 GT and it is equally faint and difficult to hear at low speed (window down). Perhaps Marius is driving in a more enclosed area (narrow street) like he said that is why he is able to hear it easily.Originally posted by logger View PostYes crawling at 700rpm with windows down. Plant the foot. Even applying a handful of handbrake to load things up. Mine is FAINT and extremely difficult to hear. You can just discern a rumble for about a second. On my installation you would not describe it as a whine at all. Must be better sound damped than your GT for whatever reason.
perhaps my perception of a distinct whine (helped along by narrow alley) is in fact the same "faint whine" you guys are hearing...
who knows!?
triode12 - you're in Sydney. maybe we will compare each others noisy and not so noisy engines one day!!!Current - MY16 2015 Octavia VRS Wagon 220 tsi DSG Corrida Red, tech, Leather, 18" black
Sounds good.Originally posted by MariusGT View Postperhaps my perception of a distinct whine (helped along by narrow alley) is in fact the same "faint whine" you guys are hearing...
who knows!?
Well. In relation to the Water pump issue (chirp/squeek sound upon acceleration), i just had my 15000KM service at a different dealership to where the problem was first attempted to be fixed.Originally posted by MariusGT View Postahh yes, i remember reading the line from VW HQ in regard to the sound. quite sure it has been posted somewhere in this very thread (i'm not wading back through the pages to find it).
i believe it was along the lines that logger mentioned --> and concluded the engineering side was not effected. ie: no loss of power functionality or longevity of parts. The ONLY reason they are trying to find a fix is because people don't like the sound.
imagine how unpopular TDI engines would be if sound alone was such a contributing factor (i actually love the truck noise combined with turbo whistle).
while i do understand some may NOT like the sound --> my GT Sport is one of those cars where on a quiet stretch i wind the windows down and turn the radio off just so i CAN hear all the squealing, whistling and exhaust farting (DSG up shifting)!!!!
==> The delarership attached a little sheet to my invoice which reads along the lines of "VW recognises there is a problem etc, VW is currently working on a solution to address the issue. If you are not informed within 4 weeks, please notify us".
I understand that we already knew VW was working on a solution, however this post is just for those people on this forum that are trying to downgrade the the issue, in that it is not an issue and it is only a noise that should be put up with. VW recognises it is a problem, and they were quite suprised how loud the chrip sound was, they said it was as if a bird was sitting inside the car chirping away.
We developed the squeal after the car (2009 TSI11
had its clutchs replaced.
Now we have had the engine replaced - it still makes the noise. When it goes in for its next service I will ask Kloster VW what they can do about it.2009 Golf 118TSI - United Grey Leather, Sunroof, Stability Control.
Clutch replaced, Engine replaced, ECU replaced
Alternator & Battery replaced Gearbox replaced
I have the squeal too
My car is 10 months old, 10,500kms, and yesterday I noticed the squeal for the first time.
Its quite faint, but 100% noticeable.
Happens when accelerating, and I could notice it 2 or 3 times a minute in typical city driving.
I'll have my 12 months service soon, so I'll see what they say.
