I picked up a wagon on the weekend, the car drives then gets the flashing gear selector. Got the error codes as below.
CAYC engine and NTS DSG gearbox, from initial readings on the forum, I’m guessing the mechatronic unit is stuffed
my question is can I get any DSG gearbox and fit? Or do I need to find one that is NTS? The car is complianced as built 1/2013
thanks for any responses.
============1==============
U0101
Raw code: C101
ECU: Engine control unit
Status: Confirmed
OBDII: Data bus, transmission control module (TCM) - no communication
============2==============
6088
Raw code: 0017C8
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============3==============
1315
Raw code: 0523
ECU: 19. CAN Gateway
Status: Test conditions are met, Validated and stored in non volatile memory
Volkswagen: Gearbox control unit; Transmission control unit
============4==============
5636
Raw code: 1604
ECU: 02. Transmission control unit[Archive (inactive)]
Status: Validated and stored in non volatile memory
Volkswagen: B1291F5: Multimedia system control head
Button for telephone "TEL"
Volkswagen: Control unit faulty
============5==============
6228
Raw code: 1854
Volkswagen: Data bus drive defective
============6==============
1830
Raw code: 0726
Volkswagen: U147300: External sound amplifier
no communication
Volkswagen: Fog lamp; Lamps for rear fog lights; Speed signal from engine control unit implausible signal
============7==============
1315
Raw code: 0523
ECU: 03. ABS control unit
Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
============8==============
6088
Raw code: 0017C8
ECU: 01. Engine control unit
============9==============
1315
Raw code: 0523
ECU: 09. Onboard supply control unit
U0101
Raw code: C101
Status: Confirmed
6088
Raw code: 0017C8
1315
Raw code: 0523
5636
Raw code: 1604
6228
Raw code: 1854
1830
Raw code: 0726
no communication
1315
Raw code: 0523
6088
Raw code: 0017C8
1315
Raw code: 0523
