Hi all,
I had an 8 sensor PDC OPS retrofitted on Golf mk6 2.0TDI 140hp several weeks ago in a local garage.
Unfortunatelly, the module was faulty (not OEM) and the guy who mounted the OPS advised me to buy a new one.
I purchased one from eBay (OEM) with part number 5K0919475E.
Now, I cannot visit the local garage because they messed up other parts of the car (this is another story) and after fitting the new module I get a long beep and a flashing rear sensors button. I purchased a VCDS to check what is going on and got this code error:
	I gues the error code is pretty self explanatory - the new module needs to be coded.
I will very much appreciate if anyone can help with the coding part or at least share some resources that would
help me code the module.
Code:
	Address 10: Park/Steer Assist (J446)  Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
   Component: PARKHILFE 8K H01 0012
   Revision: -------- Serial number: 12532131601725
   Coding: 000000
   Shop #: WSC 00000 000 00000
   VCID: 387CBFD4B3621447CF-806C
1 Fault Found:
01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
        Fault Status: 01100000
        Fault Priority: 3
        Fault Frequency: 1
        Reset counter: 220
        Mileage: 188557 km
        Time Indication: 0
        Date: 2016.11.28
        Time: 21:30:59
    Freeze Frame: Temperature: 30.0°C
