Catalytic Converter Warning Light
  • Catalytic Converter Warning Light
    Hi, I have a 2012 118 tsi Golf Hatch. Twice in the last 2 days the Catalytic Converter warning light has come on for a while then gone off. This was also accompanied by an intermittent loss of power. I fear the worse, does anyone have experience with this warning light and its ramifications !
    Only way to find out is to have it scanned, and go from there.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      SO the initial diagnosis from the local garage is it : "requires the intake manifold to be removed for inspection and manual cleaning of the valves" they recommend " regular cleaning of the the induction system to reduce carbon build up on the valves and induction ports" .
      Does anyone have thi done to their car "regular cleaning of the the induction system........"
        Fairly typical for direct injection engines these days.
        As far as regular cleaning goes, a can of intake cleaner such as that from Liqui-Moly through the system every service will keep the carbon build-up to a minimum.
        '01 Beetle 2.0
          That seems to be a fairly easy and mandatory thing to do ...I wonder why it wasnt done at my last service!
            Not everyone wants to pay for it, which is why it'd be a case-by-case scenario.
            '01 Beetle 2.0
              UPDATE....it appears that the problem was "broken earth wire in the turbo boost sensor connection" fixed for $187.
