[solved] G'day all
I'm having a perplexing problem with my 1.6 MkV.
*Fuel consumption raises from 0.6-0.7 l/hr to 1.2-1.4 l/hr
*Idle surges, can occasionally stall
*Surging can be felt up to about 2000 RPM regardless of load
*Occasional reduction/loss of brake boost
But only if started when already warm, or driven for a fair while. VCDS codes are attached. I can't seem to upload the full scan as .txt
The car drives perfect for 20-30min, up to 2 hours if freeway driving. Symptoms appear after this.
*Symptoms appear immediately if car is restarted once warm, even if only driven for 10-15 min.
*Driving for approx 10 min after symptoms start sets ASR button, stability control dash light.
Fault codes don't appear to be set until after the ASR and stability lights come on. I checked codes today after warming up, but before restarting. No fault codes, but got the problems as soon as I restarted the car. I checked again, no codes. Codes were there when I got home 20 min later.
Things I've checked:
EGR Valve (electronic) - had minimal carbon buildup. cleaned it anyway, no change. Also ran the adaptation and got ADP OK. No visible damage to cables.
MAP/Intake Temp sensor - checked connector, in good condition. No buildup on sensor heads. No visible damage to cables.
Visual check of grounds - no apparent issues.
Has anyone experienced this before? Any suggestions what to try next?
Causes:
Problem was caused by a temperature related EGR malfunction. The valve stuck in the open position when hot, but tested normal when cool.
Additionally the oil dipstick tube was not properly seated to the engine, and the crankcase breather tube was missing it's upper clamp. These alone would also have caused the same problems, excluding the high IAT.
Causes:
Recurrent Fault Codes - occur every drive after restart
17811 - EGR System - Regulation Deviation - Intermittent
Most Common| rare
Load1 83.5% | Load1 83.5%
Load2 3.1% | Load2 3.9%
16496 - Intake Air Temp. Sensor (G42) - Signal too Low - Intermittent
Most Common | rare
Temp 126.0c | 129.0c
ABS Brakes: (all instances)
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Fault codes found more than once:
16784 EGR Malfunction Intermittent
Load 83.5%
Load 0%
16520 Lambda Sensor B1S2 Malfunction in Circuit - intermittent
RPM 1376
M.Air/rev 81.8
BIN 00100000
V 0.300V
RPM 1120
M.Air/rev 76.3
BIN 00100000
V 0.920V
Most Common| rare
Most Common | rare
Load 83.5%
Load 0%
RPM 1376
M.Air/rev 81.8
BIN 00100000
V 0.300V
RPM 1120
M.Air/rev 76.3
BIN 00100000
V 0.920V
