Correct. The Kufatec E-MFA add-on displays digital speed, oil temp, water temp, battery volts and a choice between engine RPM or litres left in the tank. Turbo cars have other choices. The one I have in my 3C Passat is also suitable for Mk 5 Golf/Jetta. I love it. One of the best mods I've made. The only downside is the add-on display has to be manually selected every time you start the car.
Also, I believe the digital speedo is more accurate. At 60 km/h indicated on the analogue speedo, digital display says 58 km/h. At 100 km/h indicated on analogue speedo, digital display says 96. Now I set my cruise control at 106 believing I'm doing an actual 102.
More details here:
[ATTACH=CONFIG]27725[/ATTACH]
More details here:
More details here:
Go buy a ~$15 OBD2 Bluetooth dongle from ebay, plug it into your OBD2 port under your steering wheel and download 'Torque' for android. That can display your real digital speed on your phone. So just mount your phone on your windscreen or dashboard and you'll basically have the same thing.
