Hi guys, just wondering if anyone can offer some assistance here. I have had this GTd golf now for 2 years and it seems cursed with electrical issues.
Everything from injector failure to interior lighting. I have ironed out much of it but yesterday the car stopped and wont turn on.
Last thing fixed on the car was the G28 sensor ( replaced 2 months ago. ). this seems to be persistent error together with fuel pump relay error.
Now I have below errors and as car is a non mover. Any help would be appreciated as this car has now cost me a small fortune.
__________________________________________________ _____________________________________
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ8U002011 Mileage: 125670km-78087miles
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
Component: R4 2.0l PPD1.2 G 1155
Revision: --H42--- Serial number: VWX7Z0G43NO1FZ
Coding: 0000078
Shop #: WSC 00046 412 00000
VCID: 6BD5F48C4A26DB66B4-803F
1 Fault Found:
000801 - Engine Speed Sensor (G2
P0321 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 125679 km
Time Indication: 0
Date: 2000.00.00
Time: 01:25:49
Freeze Frame:
RPM: 128 /min
Torque: 96.0 Nm
Speed: 0.0 km/h
Time: 0.01 s
Angle: 0.0 ∞
Bin. Bits: 00000000
Bin. Bits: 00000001
Readiness: N/A
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 044 L HW: 02E 927 770 AE
Component: GSG DSG 081 1403
Revision: 04608010 Serial number: 00000704301340
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1E33ED58C914FECE63-804B
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
VCID: 73E5ECEC121603A67C-8027
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78FFDBC00B7060FE49-802D
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007980938
Coding: E58D8F2700041500471400001400000000087F075C00010000 0000000000
VCID: 71E9E6E4680A31B68E-8025
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 140707 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 310806 020 0105
Coding: 00208933
Shop #: WSC 00046
4 Faults Found:
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
OFF
OFF
OFF
OFF
02092 - Enabling Heated Seat
Freeze Frame:
Fault Status: 01111001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
OFF
OFF
OFF
OFF
02399 - Control Circuit for Terminal 30 for Interior Illumination
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.45 V
OFF
OFF
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 111
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
OFF
OFF
OFF
OFF
Coding: 0000078
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 125679 km
Time Indication: 0
Date: 2000.00.00
Time: 01:25:49
Freeze Frame:
RPM: 128 /min
Torque: 96.0 Nm
Speed: 0.0 km/h
Time: 0.01 s
Angle: 0.0 ∞
Bin. Bits: 00000000
Bin. Bits: 00000001
Readiness: N/A
Coding: 0000020
Revision: 00H11001
Coding: 0023170
1 Fault Found:
Coding: 00049109
Shop #: WSC 00046
Coding: 00208933
Shop #: WSC 00046
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.45 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Reset counter: 214
Mileage: 123632 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
OFF
OFF
OFF
OFF
