Broken rear outside door handle
  • Broken rear outside door handle
    Hi all
    So someone pulled the rear door handle too hard when it was locked and now it has popped out and wont go back in.
    The door is locking and unlocking fine and the handle is working fine, its just annoying the hell out of me!!
    What to do???
    Need to strip and inspect.
    Outer door skin requires removal for this.
      Pop off the plastic strip on the outer edge of the door
      Look for a hole with clear plastic sticker over it
      Use a Torx size 20 to loosen the screw
      This will release the lock barrel section
      Remove the lock section then have a look for a black clip thing on the end of a wire
      Move the clip a bit further out on the handle
      No need to.remove the door skin
      Sent from my C6903 using Tapatalk
      MK4 GTI - Sold
      MK5 Jetta Turbo - Sold
        Follow this guide
        Door skin removal and door handle replacement - mk5 VW | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
        Once you get to here you should be able to fix it.
        MK4 GTI - Sold
